I recently bought Celestion 6000 Subs. There is a big issue with them: 2 of the half balls are dented. One was cleaned by the original owner with water, so it lost it's tension, the other one got a small scuff (minor dent.) Any idea where I can get replacement covers or how to get the shape fixed again??? All ideas are welcome. (The material seems to be some textile, with a kind of water soluable glue to strenghthen it.) I contacted "Hifi Profis" Darmstadt (Germany) and Celestion, but they seem not to be interested in helping me with such an old item (No answer) Regs, Dirk |
#2 | |
A vacuum cleaner with a small funnel can suck dents out of dustcaps. Duct tape or Gorrilla tape (preferred) can sometimes work for pulling dents. A needle or push pin can also be used, the small hole covered with glue. |
#3 |
thanks for your answer, but that's not the point: The textile lost its tension, so even pushing it back, it does not stay in the old shape... It's some strenghtened textile, but with the strenghtened material washed out... Any owner of the subs suffering the same trouble??? |
#4 |
How about the speaker cone itself? If the dustcap is that bad I'd be worried that the cone might be a little weak as well....
#5 |
maybe I didn't state it correct: The Loadspeaker is ok, but the half ball covers are dented. Any Idea??? To improve imagination: http://www.stereophile.com/images/ar...rt/cel6000.jpg Left: Cover removed Right: Cover mounted Regs, Dirk |
#6 |
There are various fabric stiffeners available as sprays which could do the trick and to reform the ball shape a large balloon or similar could be used to create the dome shape while the stiffener dries. Finally you can respray the whole with fabric paint. the small dent should be fixable in the same sort of way.
#7 |
#8 |
Good ideas - will try as soon as I find some time. I'll report on the results... ;-)))
#9 |
Where can I get plans for these subs? I have some Celestion SL6S speakers would love a pair of matching subs
| Help in building Celestion sl 6000 sub | DAVOhorn58 | Subwoofers | 5 | 12th March 2009 02:39 AM |
| Beomaster 6000 Service | dshambala | Parts | 5 | 13th February 2009 11:43 PM |
| Celestion Ditton 66 midrang needs repair | cbriere | Multi-Way | 0 | 10th December 2007 06:35 PM |
| Technics SB-6000 | Blindet | Full Range | 0 | 22nd April 2007 10:06 PM |
| Anyone got a JBL GTO 6000 ? | andey | Car Audio | 2 | 5th December 2004 06:06 PM |
