TH-18  Flat to 35hz!  (Xoc1's design)
Old 16th September 2012, 03:22 AM   #941
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
REW generator filtered 10-60Hz pink noise will do.
Dan
Old 16th September 2012, 03:33 AM   #942
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Default Hi,
I did some rechecking and your right some are off ,by as much as 15mm,But I'm old I work by myself ,It's not perfect but I think close will do,I am not a cabinet maker,I don't have fine equipment,most of it is 20 years old or older,I should have done better ,but I tried,I did my best, so it's ok with me! I got another one to build maybe I have learned enough to do a better job next time!
So wish me luck!
Have a GREAT day I am!
NS
Old 16th September 2012, 03:39 AM   #943
NEO Dan's Avatar
The joinery looks OK, and as long as the adhesive is cured you should be OK. What did you use for construction goo?
added:
You got any BMF subs?
Dan
Old 16th September 2012, 04:22 AM   #944
noSmoking's Avatar
Used PL 375 Pro construction adhesive,and screws and screws,lol.I put them when I could about every 4 " some stiffereners only got 2 or three screws but were it a tight fit,glued all joints all the way around.
I have one 18" peavey and 2 12 kickers 12c
Old 16th September 2012, 07:21 AM   #945
weltersys is online now weltersys  United States
weltersys's Avatar
Originally Posted by noSmoking View Post
Hi Djim,
I all done, gosh took this old man 4 days to get one cabinet together,looks like the dems are off 10 to 15 mm in some places ,I'm not going to tell the speaker cause it can't see around the first bend,lol.just kidding
We will see tomorrow, I wonder how long it will take to break that woofer in,any Ideas?
Thanks !
NS
Depends on how much power you give it.
If you run a speaker to Xmax with a sine wave at Fs open air for a couple hours it should be "broken in", start a few mm below Xmax in anticipation of the suspension loosing up, don't want to hit Xlim in the process.
Since the cabinet is already built, just run AC/DC "Hell's Bells" through it full tilt boogie and it will be broken in.
Old 16th September 2012, 09:25 AM   #946
noSmoking's Avatar
Hi weltersys,
Thanks for the info and AC/DC will rock,lol.
NS
Old 16th September 2012, 04:21 PM   #947
tb46 is offline tb46  United States
Hi noSmoking,
As NEO Dan says: "...you should be OK...."
Just thought the dimensions didn't quite look correct, and wanted to give you a heads up. The pictures of the throat area look interesting. I'm looking forward to hear your description of what they sound like.
Oliver
Old 16th September 2012, 08:59 PM   #948
ODougbo is offline ODougbo  United States
As you say, don't smoke the voice coil.
The foam looks good, I don't think it is done expanding - never "trap" that stuff, it could lift a car (from pressure).
Hi weltersys,
NS
Old 16th September 2012, 09:15 PM   #949
noSmoking's Avatar
Hi ODougbo,
It was set before I closed it up,Just checked the panel and thier fine, the pl is still soft in some spots so it's going to sit until it hard,Cool and raining here today,but we need rain here bad,so
The next thing is some WHEELS this is getting heavy and will be more than I can lift when the speaker goes in,lol thinking about doubling the bottom panel ot at least some large pieces for the casters to mount on,
Time to build the voltage probe for ARTA,,,,,,
NS
Old 17th September 2012, 05:11 AM   #950
noSmoking's Avatar
Default Thanks ,Oliver
Originally Posted by tb46 View Post
Hi noSmoking,
I am waiting on the PL350 to Dry out fully,It's almost a tan color and getting hard,some places I felt still are soft ,so a little Time to built a voltage probe,lol!
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
