TH-18 Flat to 35hz! (Xoc1's design) - Page 89 - diyAudio
Old 13th September 2012, 02:50 PM   #881
tb46 is offline tb46  United States
Hi Y'all,
I have used T-nuts for a long time, and if you watch what you're doing they are fine; but, so called hurricane nuts are probably better, e.g.: http://www.parts-express.com/pe/show...umber=081-1084, and the barbed body inserts are better yet: http://www.parts-express.com/pe/show...umber=081-1094. The hurricane nuts,and barbed inserts need well cut clean holes, the T-nuts are a little more forgiving, but have a tendency to fall out unless expoxied in place.
In the LAB12 TH thread, Post #25/27(corrected link) layertone gives a link to self-tapping, threaded inserts (in my opinion they are the best):
Lab12 - Tapped Horn -
And make certain you get the blue Loctite #242, or you'll be in trouble.
Oliver
Old 13th September 2012, 02:56 PM   #882
ODougbo is offline ODougbo  United States
I would hate to use locktite wtih a wood tee nut, it could "strip"..Now that would be a mess, never get that out.
Old 13th September 2012, 03:12 PM   #883
epa is offline epa  Netherlands
nice to see your making sawdust
make sure you post the finnished pics.
Originally Posted by ODougbo View Post
....whats with the blue paint?
i think its an easy way to mark the pannels for holes and glue.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 13th September 2012, 04:39 PM   #884
Yes I did think of that, but never seal wood before glue (in case something moves)
btw, How flat of a response will it have? How low will it go?
Would really like to see it finished also!! But that said I wish I never saw the first set of Pics.
[becuase I want one]
Old 13th September 2012, 08:38 PM   #885
noSmoking's Avatar
hi all,
The blue paint is there so when I take it back apart(I make a mockup assembly first minimal screws) and then spray paint the edges,then you can drill 2 sides at once and have them square and in place and make sure the screw hits the middle of the board,I also use a magic marker to show screw lines across the top of angled boards for pre drill/counter sinking,
I found out it will be best to start reassembly from the inside out, my power drill won't fit in the smaller spaces outherwise,
Thanks Epa ,I got sawdust and a bunch of long skinny triangles,They might work as gussets,lol
Cheers!
NS
Old 13th September 2012, 08:56 PM   #886
noSmoking's Avatar
Default Blue Paint....
Here's a couple more pics,
Old 13th September 2012, 09:13 PM   #887
kctess5 is offline kctess5  United States
Here's my contribution...
I hope mine live up to all the others that have been put up recently
I should get some better pics as I build. I got a CM140 SPL meter for my measurements, so I can throw up those once this one is done and I can take it down to the field.
This sub is 1 of 4 Still have to add cabinet hardware and paint, should be able to do some testing next week
Old 13th September 2012, 09:17 PM   #888
Is it ok just to attach the driver with wood screws? If I have to go back to home depot it means purchase orders and purchase orders and purchase orders and purchase orders...
I must say that the paperwork associated with doing all of this for the school is very annoying, I am used to just doing my own thing and just buying things when I need them
Old 13th September 2012, 11:59 PM   #889
djk is offline djk
djk's Avatar
Use #10 Pan head sheet metal screws instead.
Candidates for the Darwin Award should not read this author.
Old 14th September 2012, 12:38 AM   #890
Check McMaster-carr.com: "screws" you'll find something;
Hex Head?
e.g. McMaster-Carr
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 03:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 23rd September 2015 12:32 AM
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 10:22 AM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 03:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 08:38 AM
Copyright 1999-2017 diyAudio
