TH-18  Flat to 35hz!  (Xoc1's design)
Old 22nd June 2012, 09:32 PM   #661
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
I have a pair of 18 inch TC Sounds LMS Ultra 5400. Who has designs for them? Push-pull, bandpass etc.
Old 23rd June 2012, 04:00 AM   #662
m R g S r is offline m R g S r  United States
Josh Ricci has designed a nice horn around those....
Gjallerhorn
It's a huge heavy cabinet...
Old 1st July 2012, 12:12 PM   #663
CRESCENDO is offline CRESCENDO  United States
Originally Posted by NEO Dan View Post
The pdf spec was -4dB @ 35Hz/ -10dB @ 28Hz.
The old website had it at 40-250Hz
My 2010 TH-118 pdf. reads:
40 Hz - 250 Hz -3dB
28 Hz - 300 Hz -10dB
The 2010 TH-115 pdf. reads:
38 Hz - 200 Hz -3dB
33 Hz - 280 Hz -10dB
Old 1st July 2012, 02:12 PM   #664
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
pdf's are back:Spec Sheets | Danley Sound Labs | Danley Sound Labs, Inc.
Dan
Old 3rd July 2012, 03:58 PM   #665
Is the TH-112 new? Says it digs down to 33hz..interesting! I like 12" designs but don't see that many at all.
Old 3rd July 2012, 04:29 PM   #666
rpowell is offline rpowell  United States
The TH 112 has been around for awhile. It goes a little lower in frequency response than the TH 115 but not as much output. It has never been too popular an item in the Danley line, but I guess there's an app for everything.
Old 3rd July 2012, 05:53 PM   #667
NEO Dan's Avatar
Looks like the TH-112 goes back to 2005
Dan
Old 22nd July 2012, 04:30 PM   #668
shello79 is offline shello79  St Lucia
Lets see if we could put some life back into this thread
Old 22nd July 2012, 09:08 PM   #669
shello79, I think there is some hesitation to start diagramming and modeling a horn that is too close to the "real" Danley TH118. xoc1's current design is a good performer and he has all the plans and cut sheets need to build one if you are so inclined. And there's enough anecdotal information on this thread to take the design in the direction of making a *ahem* copy if you are so inclined to do so on your own.
Old 6th August 2012, 04:33 PM   #670
jwmbro is offline jwmbro  United States
jwmbro's Avatar
I wonder, how close are the designs? I see the outside size is the same, and I've seen how close the wireframe models are, and I recall reading somewhere in this thread that Danley uses B&C. But even so... I've looked at the sensitivity ratings, and the TH 118 has 108dB @ 2W with -3dB at 40Hz.
I've run most the designs in here through hornresp as best I could, along with a few of my own attempts at a design, and the best I could do was 105dB.
(for example: B&C 18SW115 in a 330l horn - 4.0Volts in 8Ohm nominal, 105dB)
Where does Danley manage to double the efficiency? Or is HR somehow not accounting for something? Because 3dB is a lot of gain.
Regards, James
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
