TH-18  Flat to 35hz!  (Xoc1's design)
Old 14th February 2012, 10:58 AM   #491
scameron78 is offline scameron78  United States
so with Xco1's T18 here, should the baffle have this shape?
Old 14th February 2012, 03:27 PM   #492
weltersys is offline weltersys  United States
weltersys's Avatar
Without performing an A/B test, hard to say.
PASC did mention the Keystone TH design had better cone control than the TH18 design using the same speaker, perhaps you could ask him to try the shaped plate and see if it helps.
Or DIY .
Art
Old 27th February 2012, 12:27 AM   #493
CRESCENDO is offline CRESCENDO  United States
Or DIY .
Art
@Scameron: or at least build the plate and ship it to him to test
Old 29th February 2012, 07:04 AM   #494
grec13 is offline grec13  United States
Default Keystone TH compatability
Aloha everybody.
I got a question for Art.
First of all.
Thank you for sharing your knowledge and experience with us.
I'm looking for home bass solution in 35-90hz range.
Will the JBL LE14A or JBL 2235H work in the Keystone TH?
I tried Martinson TH15, it didn't work with them. Seems like a sound is choking inside the cabinet.
thank you.
Or DIY .
Art
Sergey
Old 29th February 2012, 03:45 PM   #495
weltersys's Avatar
Originally Posted by grec13 View Post
Aloha everybody.
First of all.
thank you.
Sergey,
Although every speaker put in the Keystone "worked", work is a relative term. The Eminence 4015LF had decent frequency response, but the relatively lightweight cone, fine in a ported cabinet, distorted badly when pushed to Xmax in the tapped horn. Sims don't show distortion.
The JBL cones you ask about would probably fare little better (and possibly worse) than the 4015LF.
The LE14A only has an Xmax of 5.08mm, the 2235H is only 8.38mm.
The B&C18SW115 has an Xmax of around 15, three times the former, and almost double the latter.
Doubling Xmax allows for about 6 dB more output.
B&C now has a new cheaper (heavier slab magnet) driver, the 18TBW100 (4 or 8 ohm) with similar specs to the 18SW115.
It models well in both XOC1's TH-18 or the Keystone, though in the Keystone it can take more power before exceeding Xmax, and put out a bit more level.
Art
Old 29th February 2012, 03:59 PM   #496
fhperez is offline fhperez  United States
Send a message via AIM to fhperez Send a message via MSN to fhperez Send a message via Yahoo to fhperez TH-18  Flat to 35hz!  (Xoc1's design)
Sergey,
Art
Have you guys posted those numbers anywhere?
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!!
Old 29th February 2012, 06:57 PM   #497
thank you Art.
Sergey,
Art
Sergey
Old 29th February 2012, 07:48 PM   #498
weltersys's Avatar
tundraLTD in post #3 of this wrote:
http://www.diyaudio.com/forums/subwo...-b-c-18-a.html
ďJust plugged it into my Akabak script of the TH-18 Flat to 35hz! (Xoc1's design)
It sims great hitting Xmax at just over 900w. I may have to order a few! Thanks for the find.Ē
The Xoc1 TH-18 as built rolls off below 50 Hz, the Keystone (like the Danley TH-118) rolls off below 40 Hz, closer to "Flat to 35Hz!" .
The higher LF knee of the Xoc1 TH-18 allows it to play louder higher, but excursion goes up below Fb, so it canít take as much power without sounding, a bit distressed.
The simís below show very little difference in output at Xmax for the new BC18TBW100 and the BC18SW115.
The BC18TBW100 has an Xmech (where mechanical damage will occur) of 28.5mm, Hornresp says it would take 138 volts (5874 watts in the Keystone sim) to reach that, and it would hit over 135 dB.
In real life with music, thermal compression and the stiff compliance would probably not allow hitting Xmech and long term power of around 6000 watts would probably smoke the driver, but the BC18SW115-4 has no problem with 120 volt peaks, I expect the BC18TBW100-4 would not either.
Art
Old 1st March 2012, 03:59 AM   #499
Djim is offline Djim  Netherlands
Hi Art,
If cut with >24dB/oct at 37Hz, drivers in the Xoc1 can handle their AES power ratings.
Old 1st March 2012, 04:54 AM   #500
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
The 18TBW100 with a 12dB Butterworth highpass @ 32Hz will do 900+watts. With a L/R 12dB highpass 1600+watts. Akabak sims show nearly NO difference in SPL output so why would you push it that much harder?
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
