TH-18  Flat to 35hz!  (Xoc1's design)
Old 14th June 2011, 02:11 AM   #41
m R g S r is offline m R g S r  United States
Djim that comparison isn't really fair showing the difference between the two. What I mean is, at 1w input they seem very close. When in reality the ss15 runs out of steam wayyy before the TH-18 does. Xmax is exceeded with around 56 volts if I remember correctly on the ss15, and on the TH-18 it is nearly double that.
Old 14th June 2011, 02:40 AM   #42
CRESCENDO is offline CRESCENDO  United States
Glad you pointed that out, m R g S r.
Efficiency, yes. Total output, no.
Old 14th June 2011, 03:02 AM   #43
Djim is offline Djim  Netherlands
2,83V isn't the same as 1watt, and yes the SS15 loaded with 3015lf will be run out even before the continue power of the TH18 loaded with 18Sound. The only reason I made the comparison was to show they can go together without issues.
4 x SS15 loaded with RCF L15P200AK's (8ohm versions) + 2 x TH18 loaded with 18Sound 18LW2400 (4Ohm version) gives all kinds of options from small to medium gigs. You can even run them from one 2 x 4000 watt (2Ohm) amp if necessary.
Or if you don't need the SPL you can run them all from a 2 x 2000W (2Ohm) amp that is also able to power 2 x 1600 (4Ohm) for two TH18's or four SS15's and even 2 x 1000 (8Ohm) for two SS15's. After a while you can expand with a second amp (if needed). That way you can create a versatile setup with lots of possibilities.
Old 14th June 2011, 03:16 AM   #44
Sorry I just assumed 1 watt on the first sim...
Again thanks for the comparison and the info!
Old 14th June 2011, 04:42 AM   #45
Originally Posted by scameron78 View Post
would a peavey lowrider or one of the eminence 18" drivers work in this cabinet. i was getting ready to cut 2 of jbell's SS15, but i saw this thread. i am just looking for a cabinet to use for live band application only. so i will never need anything below say 45hz.
For 225$ you can have the P.Audio C18-650EL. It has double spider, demodulation ring, high headroom (AES 1200Watt - 2400W max), high quality build with tight tolerances and sims good in the Xoc1-TH18.
Old 14th June 2011, 04:49 AM   #46
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Great thread, I really like the folding stuff in CAD, that seems to offer better precision and tweakability compared to doing it on paper.
I wonder if the Void V18-1000 driver would work well in this enclosure?
It's priced around the same as the 18LW2400 (in the UK at least), offers higher Xmax, had a larger voice coil and also has a higher BL value so is probably another driver to consider if you can get hold of it that is.
Old 14th June 2011, 04:59 AM   #47
Me too maybe you could show us!
Old 14th June 2011, 05:41 AM   #48
MikeHunt79's Avatar
Ok, I have the driver specs and the latest version hornresp downloaded, once I've worked out the S and horn path length values for this enclosure I'll post up a frequency plot.
Old 14th June 2011, 06:52 AM   #49
MikeHunt79's Avatar
Ok, I think I managed to piece together enough data to run a few sims now:
The black line is the 18LW2400
The grey line is the V18-1000
The Void driver does pretty well I think, I've tried to use the similar settings to the picture in the first post, SPL is at Xmax+1.6mm using 4 speakers. I'd love to hear 4 of these in full effect with a decent amp...
Old 14th June 2011, 06:55 AM   #50
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Looks like a winner, how much drive voltage to get there?
Dan
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
