TH-18  Flat to 35hz!  (Xoc1's design)
Old 26th January 2012, 07:38 PM   #461
Djim is offline Djim  Netherlands
Hi Martin,
Your optimised SS15 also gives very good results with an 270mm extender in combination with the RCF and Moncacor drivers.
Old 26th January 2012, 07:52 PM   #462
tb46 is offline tb46  United States
Hi Djim,
How do you model this?
Oliver
Old 26th January 2012, 08:28 PM   #463
Hi Oliver,
I do it two ways and check the differences; one way is to stretch the concept like usual, and the other way is to use "TH1" in the "Input Parameter" page and recalculate the positions, that Neo Dan pointed out to me. The last one looses the capability to put a horn parameter between S2 and S4. It would be better if you use Akabak, but I hope David will increase the number of horn parameters. Besides, there are more important things you can't model.
Old 26th January 2012, 08:30 PM   #464
Hi Djim,
Thanks. Yes, this does call for AkAbak.
Oliver
Old 26th January 2012, 08:44 PM   #465
Hi Oliver,
Let me put it this way, maybe its not optimised, but it does improve compression figures considerably and gives low freq. extension for the drivers mentioned in my earlier post. It's not tested with the 3015lf (as far as i know) but I think it will be less promising.
Old 27th January 2012, 12:33 AM   #466
Hi Oliver,
To prevent confusion, my extender is based on the Xoc1 optimised SS15 with 12mm sheet of post#737 of the Single sheet TH challenge thread.
Old 27th January 2012, 03:06 AM   #467
Black is closest in volume.
Black and Grey line are Xoc1 optimised.
Green line is standard SS15 from JBell.
Old 27th January 2012, 12:33 PM   #468
epa is offline epa  Netherlands
Hi Djim,
oftopic ,how does one run akabak under win7 x64?
i tryed compatebilety mode and dos envirement.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 27th January 2012, 01:05 PM   #469
nvm
i run it in a virtual machine ,xp.
. hr driver db
Old 27th January 2012, 01:08 PM   #470
Hi epa,
I'm running Xp, and will as long as possible. Sorry, but no further help.
Oliver
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
