#21 |
ehh it starts falling off before 40hz...this is supposed to be flat to 35! (semi flat)
#22 | |
Remember your own words
#23 |
Hi Djim,
Thanks for this - looks like i will have to try a pair of these.. Presume if these are run in close pairs this should improve the response below 40hz? Excuse the basic questions but how well do tapped horns take to eq being applied to extend response a little - do they unload the driver below tuning and x max will be the problem? Thanks again, Luke |
#24 | |
I'll try to explain as good as I can. Stacking multiple Tapped Horns will not lower the resonance of the design as HornResp predicts. But in this case the design limit (1/3 wavelength) is set out on 38Hz. So the response in stacks will get a boost at all frequencies above 38Hz but the 'knee' (point were the response drops) will never go below 38Hz in reality like some predictions suggest. So, there is no need to worry about Xmax. However, you will need a low-cut filter (same as high-pass) to prevent extreme excursion. The settings for this low-cut filter haven't been modelled yet. |
#25 |
how does the BMS 15N840 fare in these sub 40hz designs? Good?
#26 |
Sorry luke, forgot to mention that EQ-ing doesn't make your amp grow bigger. I mean if you use a power amplifier that is able to produce 1500W you can boost whatever you like because the amp will never produce more than 1500Watts. Therefore in combination with the right settings for the low-cut filter the excursion will never get above safety levels.
#27 |
#28 |
Thanks for the info Djim, it all makes sense.
Looking fwd to creating some saw dust.. Will go for routed rebate contruction and brace as suggested. |
#29 |
Looking forward to see the results!
#30 |
Hi Xoc1,
Just would like to say that I appreciate your efforts very much, and hope that you can provide more insights into box behaviour as in the Ansys pictures in Post #6/11. It looks like the bottom board was used as reference in the FEA simulation, and it would be interesting to see what it looks like turned (referenced) upside down, so that the whole mouth perimeter would be able to flex. Anyway, great work, thanks. Regards,
Oliver |
| 2 18 bass design | simpleacoustic | Subwoofers | 101 | 15th May 2011 09:22 AM |
| 18 inch labhorn design. | mulletdude | Subwoofers | 21 | 12th November 2010 01:40 AM |
| Ciare 18 bass horn design | soundhead | Subwoofers | 1 | 28th March 2010 06:51 PM |
| I want my Avalanche 18 to go flat to 15hz | thadman | Subwoofers | 10 | 11th November 2006 02:54 AM |
| Looking for suggestions on a 1300W Dual 18 sub design. | mjcohen | Subwoofers | 5 | 21st December 2004 07:38 AM |
| Page generated in 0.11843 seconds (83.12% PHP - 16.88% MySQL) with 11 queries |
