TH-18  Flat to 35hz!  (Xoc1's design)
Old 27th July 2011, 06:16 PM   #281
Djim is offline Djim  Netherlands
Put the delay on your tops and you'll be fine
Old 27th July 2011, 06:19 PM   #282
m R g S r is offline m R g S r  United States
The tops are currently delayed 5.8ms and crossed high passed LR-24 at 80hz.
I thought the ss15 needs to be delayed because of the shorter path length compared to the TH-18? or am i completely off here lol
Old 27th July 2011, 06:23 PM   #283
Theoretically you are correct but I think you will prefer them without delay. (Also check if you prefer the delay for the tops on 10ms instead of the 5,9ms)
Old 27th July 2011, 06:26 PM   #284
okay cool i'll set up the third amp and ss15 and have a listen. Stacking configuration suggestions for outdoors and the 5 speakers (2 TH-18, 1 ss15, 2 JRX 125)?
I know the horns have better dispersion on their sides, I just have them stacked this way because there is no room to lie them down inside the small room.
Old 27th July 2011, 06:39 PM   #285
Actually, I don't think you will need the SS15's but always experiment and trust your ears.
Old 28th July 2011, 06:29 AM   #286
CRESCENDO is offline CRESCENDO  United States
If it's a party w/a DJ, maybe use the SS15 for the DJ's booth along with his monitor.
Old 28th July 2011, 06:31 AM   #287
Aaaaaaaand B&C's neo products finally went UP! 18SW115 went from $449 to $582
Old 28th July 2011, 06:38 AM   #288
fhperez is offline fhperez  United States
Send a message via AIM to fhperez Send a message via MSN to fhperez Send a message via Yahoo to fhperez TH-18  Flat to 35hz!  (Xoc1's design)
I just finished reading all threads posts in here, I am hooked.. I currently have 4 SS15s so... what would 2 th18s do different, I definitely do not have the money nor the space for 4 of these monsters... I am looking for more SPL, I have 4 EV ZX5s, I have 2 QSC Plx 2402s and a yamaha p7000 ... I DJ so most of the time I only use 2 of the ss15s, but there was 1 time where the 4 ss15 were not enough for the room... it could have been my configuration, but they were not enough for that room... Thanks in advance
Old 28th July 2011, 07:54 AM   #289
Where the SS15s are loud from ~50Hz on up, the TH18s are loud from 35Hz on up. So, it will depend on what style of music you play to deem the TH18 beneficial to you. With the B&C 18SW115 driver, the TH18 is about as loud as 2 to 2.5 SS15s. The TH18 weighs 3 times as much (160lbs vs. 50lbs - it's bigger, uses thicker wood: 3/4" vs. 1/2" and far more bracing) and depending on the driver, can take up to 3 times as much power (1700W vs. 500W). As far as packing more SPL in less space, the TH18 is where it's at (vs. the SS15). One TH18 costs just about as much as 2 SS15s (depending on driver and accessories), but again, will be louder than those 2 SS15s.
Old 28th July 2011, 01:47 PM   #290
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
Glad I ordered mine when I did! Need to see what wholesale went up to... I wanted to order a couple more pairs
*just looked it up, now wholesale went up 92 very sad
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
