TH-18  Flat to 35hz!  (Xoc1's design)
Old 7th March 2018, 12:17 AM   #2751
multi is offline multi  Australia
Would this driver work in a TH18 Thanks
Phil
LF18N451
  • 4,5 - inch Inside/Outside copper voice coil
  • 3000 Watt continuous program power handling
  • 97.5 dB Sensitivity
  • 30 Hz - 1 kHz Frequency range
  • Dual-forced air ventilation for minimum power compression
  • Dual spider designed with silicon based damping control
  • BL of 30.2 Txm to provide a faster and accurate low frequency
General Specifications
  • Nominal Diameter: 460/18 mm/inch
  • Rated Impedance: 8 Ω
  • Program Power: 3000 W AES
  • Power handling capacity: 1500 W AES
  • Sensitivity: 97.5 dB
  • Frequency Range: 30 Hz 1000 Hz
  • Effective Piston Diameter: 395 / 15.6 mm/inch
  • Max Excursion Before Damage (peak to peak): 60/2.36 mm/inch
  • Minimum Impedance: 6.3 Ω
  • Voice Coil Diameter: 115 / 4.5 mm/inch
  • Voice Coil Material: Copper
  • Voice Coil Winding Depth: 26 / 1.02 mm/inch
  • Number of layers: 2
  • Kind of layer: inside / outside
  • Top Plate Thickness: 15 / 0.6 mm/inch
  • Cone Material: No presed pulp
  • Cone Design: Curved
  • Surround Material: Polycotton
  • Surround Design: Triple roll
Thiele/Small Parameters
  • DC resistance: 5.0Ω
  • Mechanical factor: 6.0
  • Electrical factor: 0.25
  • Total factor: 0.24
  • BL Factor: 30.2 T m
  • Effective Moving Mass: 235 g
  • Equivalent Cas air load: 245 liters
  • Effettive piston area: 0.122 m
  • Max. linear excursion (mathematical): 8.8 mm
  • Voice - coil inductance @ 1kHz: 2.6 mH
  • Half-space efficiency: 2.54%
Mounting information
  • Overall Diameter: 465 / 18.3 mm/inch
  • Bolt Circle Diameter: 442-447 / 17.4-17.6 mm/inch
  • Bolt Hole Diameter: 6.5 / 0.25 mm/inch
  • Front Mount Baffle Cut-out: 424/16.7 mm/inch
  • Rear Mount Baffle Cut-out: 424 / 16.7 mm/inch
  • Depth: 205 / 8.1 mm/inch
  • Volume occupied by the driver: 5.5/0.19 liters/ft
  • Net Weight: 10.6 / 23.3 kg/lbs
Old 7th March 2018, 12:34 AM   #2752
LORDSANSUI is offline LORDSANSUI  Brazil
see the results bellow and make your conclusions.
Diaphragm displacement @ 1500 W = 15,0mm
Diaphragm displacement @ 520 W = 8,8mm
Old 7th March 2018, 09:49 AM   #2753
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Looks OK in the Sim Lordsansui has provided.
X max would ideally be bigger but xmech looks generous.
If Hornresp is reporting 520 w into 8 ohm - power will be more into Re and also add in 2db for compression and you are probably looking at 1000w to reach x max.
Some of the RCF drivers seem to sim well in a TH.
I was looking at the RCF LF15X401 15" yesterday looks like a killer driver in the SS15 with a 11.5mm xmax
Old 7th March 2018, 09:19 PM   #2754
Thanks Xoc1 and Lordsansui
Phil
Old 8th March 2018, 06:07 PM   #2755
radulescu is offline radulescu  Romania
Guys, I can assure you that the RCF driver you suggested is miles away from what the SW115 drivers are capable of. The xmax at 70% variation of the KMS is about 8 mm and of the BL is at 10 mm. The peak displacement that driver can have without being horrible is 12 mm. The protection value for displacement on the 18sw115 driver is 16.4 mm. Also , the thermal power handling is much lower, even though they specify it almost the same.
Old 9th March 2018, 07:23 AM   #2756
Sabbelbacke is offline Sabbelbacke  Germany
I second that. The cone stability of the B&C also is much better.
www.hornresp.net
Old 9th March 2018, 08:44 PM   #2757
Xoc1's Avatar
Looking at the comparitive prices on Blue Aran (Jam Club) The RCF LF18N451 is available at 259 while the B & C 18SW115 is 400
I would imagine that the RCF might have its place dependent on budget and amplifier power.
That is what interested me with the RCF LF15X401 available at 156 while the 18 inch RCF LF18X401 is 177 and has a 11.5 xmax.
Old 5th April 2018, 03:00 PM   #2758
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Anyone have a long-term report on the TH18 paired with the 18LW2400?
Iv got 4 18LW2400 in Bass reflex boxes and im not impressed with the SPL. So I figure the TH18 is the best choice for SPL and low bass.
Old 30th May 2018, 03:38 PM   #2759
lawbadman's Avatar
Anyone have a cut sheet for 4x8 plyboard.
Also how many sheets of ply (4X8) will I need for one box?
Old 8th June 2018, 08:38 AM   #2760
Augusts is offline Augusts  Latvia
Hi, can you please help me identify the error with Hornresp
as you can see it shows a very weird spl graph when there is more power applied to it and also it indicates insane diaphragm movement, what am I doing wrong?
The driver is 18 sound 18lw1400
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
