I put my Inuke 6000 on a CRO, and observed that the quoted power is PEAK, not rms. So id call it about 2000w @4 ohms, theoretical.The Behringer NU6000 (and NX6000) power amplifier are 2 x 3000 Watts @ 4 Ohms; 2 x 1500 Watts @ 8 Ohms, and can't be mono bridged, so you would have four spare amp sides using four amps for four cabinets..
I say theoretical as I dont believe they can sustain that power.....there is very little reserve capacitance in the inukes.
When running off a generator at high demand they sounded like they ran out of puff on each kick...a little floppy/distorted. And the lights would dip too.
The Inukes have no PFC correction, they take a lot more current than it´s nornaly needed for the output power.When running off a generator at high demand they sounded like they ran out of puff on each kick...a little floppy/distorted. And the lights would dip too.
If the lights dips , probably the voltage from the generator drops to much.
Inuke at 2000 real watts on 4 ohm is about right. +/-80V supply, full bridge, maybe 80% supply regulation. That gives 2k per channel into 4. Assuming of course the mains stay at 120V. It can actuslly sustain that for a while, but it’s not goof for it. A lot of infant mortality fails due to THERMAL CYCLING. Run ‘em for a year, get something better if you can.
If the lights were dimming, the generator (or AC cables..) were not providing enough voltage/power to sustain the peak demands, the system was "undersized".I put my Inuke 6000 on a CRO, and observed that the quoted power is PEAK, not rms. So id call it about 2000w @4 ohms, theoretical.
The generator at minimum should be capable of around 7000 watts per Inuke 6000 to keep up with their peak demands, not including any lighting loads. The cabling should be sized to not drop more than 5% at the peak draw.
The amplifiers with the best PFC could reduce peak demands by ~40%, which could reduce the generator size.
Since this gets asked about once a month, I'll summarise :
It has been stated a number of times that there are no published mk 2 plans. There are little hints here and there about changes / improvements, but no new drawing (that has been made public anyway).
There can't be a single drawing that covers all possibilities for the cone correction anyway (what people seem to want when they ask about mk 2) since a different design would be required for each different driver.
My TH18s are approaching completion, or at least complete enough to be able to run some tests.
I have an ECM8000 test mic (standard factory mic, no additional calibration) and I'm going to get a small USB audio interface to run tests with my laptop in my workshop. I also have Fluke multimeters.
I'm not able to test outside at this time, but the main floor of the workshop is a large space, so I am hoping I can get some useful measurements
Is there a guide or tutorial in this forum or elsewhere about how to make useful measurements using REW? I've been hunting on and off throughout the day and have found bits and pieces like post 1024 (see below), but nothing for noobs like me.
Examples of the kind of questions I have :
Would be very grateful to get all the info I can for this testing. Hopefully I can gather some useful data for us.
Measurement sweep setup suggestion:
- Attach multimeter to amp terminals or wire ends, speaker is not attached at this point.
- Use the REW generator to play a 60Hz sine wave and set amp output voltage, 4Ω: 2v/1m, 10v/5m, 20v/10m. Note the REW generator output level setting, and do not go higher than -12 to avoid digital clipping. Ensure there is no clipping elsewhere in the signal chain.
- Start measurement sweep dialog, set output level to the same value previously used in the generator, set frequency of sweep to 20-300Hz and select the shortest/128k sweep length and set the number of sweeps to 2.
- Click the start measuring button, if you have too much or too little input signal make corrections at the mic/input level side only.
- Look at impulse response and adjust IR windows to 25ms left and 150ms right, then click Apply Windows
- Now look at FR and phase.
- Where do you point the microphone? At which part of the driver?
- From where is the distance (eg 1m) measured? From the front of the cabinet? Or from the driver itself?
- I understand that 2.83V into 8ohms @1m is 1W @ 1m, so is this the power that I should use for the sweeps?
Been struggling to find time to progress the modelling but have made a bit more progress.
https://a360.co/3KbZStY
Have finished off the bracing and added rebates (might not suit those who don't have access to CNC). Still need to add cut outs for handles and pilot holes that are practical to add in the CNC cutting.
- Subwoofers
- TH-18 Flat to 35hz! (Xoc1's design)
