TH-18 Flat to 35hz! (Xoc1's design) - Page 23 - diyAudio
Old 25th June 2011, 07:25 PM   #221
Djim is offline Djim  Netherlands
Originally Posted by TundraLTD View Post
I just ran a sim with only 50% open area at the mouth and it still only drops 0.51dB @100Hz. As far as the 'Bubble' I believe that is because Akabak only calculates as if it were in a 2Pi environment
That is indeed a surprising result , did you calculate other settings in Akabak as well?
Old 25th June 2011, 07:40 PM   #222
TundraLTD's Avatar
Other settings?
Old 25th June 2011, 07:58 PM   #223
Sorry, with other settings I meant other settings for percentages of open area.
Old 25th June 2011, 09:09 PM   #224
TundraLTD's Avatar
From what its showing me even at 10% open there is just over a 3dB drop, it does start messing with the frequency response under 40% open or less. I've been thinking about it and thought its like having a sliding glass door between you and a noise outside, closed you can somewhat hear it but you don't have to open the door more than a crack to hear it well. I think its safe to use whatever grill material you want to use as long as it isn't solid plate steel
Old 25th June 2011, 10:08 PM   #225
tb46 is offline tb46  United States
Hi TundraLTD,
Would you share your AkAbak file? I looks like you have the details well worked out.
Oliver
Old 25th June 2011, 10:43 PM   #226
TundraLTD's Avatar
Sure, I'm cleaning it up right now and adding in some notes. I'll post it later this evening
Originally Posted by tb46 View Post
Hi TundraLTD,
Old 26th June 2011, 03:01 AM   #227
TundraLTD's Avatar
I've cleaned it up the best I can for now. If you have any questions I will try to answer them. Akabak is extremely complex and I have only been able to get this far thanks to the help of Soho54 and his Akabak for Dummies thread @AVS forum.
Have fun!
Old 26th June 2011, 04:03 AM   #228
Hi TundraLTD,
Thanks for the AkAbak file. I'll attach an AkAbak file from geitmans thread: Dual 8" tapped horn = TH-SPUD. You might find his use of viscosity interesting, maybe a grill could be modelled that way too?
Oliver
Old 26th June 2011, 04:42 AM   #229
TundraLTD's Avatar
I'm sure it could but I don't know it in depth enough to get there yet. If anyone else does and would care to explain it that would be cool. I'll rework it tomorrow like that example and see if anything changes
Old 26th June 2011, 11:28 PM   #230
TundraLTD's Avatar
Here it is again this time based on how geitmans built the spud script.
I have no idea what to do with the viscosity numbers at this point. I just used the same numbers for the equivalent area of the horn, if anyone wishes to shed some light on it that would be nice
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 09:22 AM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
Copyright 1999-2017 diyAudio
