TH-18  Flat to 35hz!  (Xoc1's design)
Old 25th March 2014, 09:39 PM   #1631
chrapladm is offline chrapladm  Australia
MMS makes sense. I was confused by the MMD comment. The 2400 has a MMS of about 190. So
18 Sound LW2400 Mms 192
18 Sound NLW9601 Mms 270
18 Sound NLW9000 Mms 218
BC TBX100 Mms 209
BC TBW100 Mms 245
BC SW115 Mms 275
Seems like the 2400 is the weakest cone. Although it has the least excursion but not by much less than the 100. 115, 9000 and 9601 have the same excursion capabilities though. Considering all these are safe in the TH18 are we just saying the 270g class can just take more punishment compared to a woofer that has the same abilities but lighter cone?
Old 25th March 2014, 09:54 PM   #1632
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I've fallen behind the flu
Be on the lookout for other contributing factors like coil material and dia/length...
Dan
Old 26th March 2014, 06:50 PM   #1633
Djim is offline Djim  Netherlands
Originally Posted by Andy1967 View Post
So the final cone correction for your 18SW100 was as you kindly shared in post 1144?
Hi Andy1967,
This one is cone correction + an increase of the compression ratio similar (but optimised this time and no longer uses round disks but sheet strips) to what I recommended for CRESCENDO's 18SW100.
Old 26th March 2014, 09:49 PM   #1634
epa is offline epa  Netherlands
Originally Posted by chrapladm View Post
What determines a weak cone?
I will be using the 18 Sound LW2400 in mine.
fyi
the 18sound 18lw2400 are used a few times in the xoc1 cab,with good results.
dont know wich post's .there was even a youtube clip somewhere here.
recently had a few in my hands and they are resonably strong cones.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 26th March 2014, 10:32 PM   #1635
Originally Posted by Djim View Post
Hi Andy1967,
Wow huge help. Thanks
Originally Posted by epa View Post
fyi
Thanks for this also. I know they have been used and wasnt really stressing using it. I am trying to decide if I want to spend the extra money for the 9000 right now anyways. Although I am thinking I will stick with the 2400.
Old 27th March 2014, 06:58 AM   #1636
Andy1967 is offline Andy1967  Denmark
Hi Andy1967,
Hi Djim,
Thanks a lot for your suggestion for cone correction in Post 1633.
I was hoping for something like this, that seems to work both as part of the throat(?), and also aims for the right compression.
The nice thing about CRESCENDOs solution is that he has documentation that he has more output with his correction. Your correction might even add something on top of that, like cone control?
I am still aiming to do some type of excursion testing when i get my SPL meter and when it gets a bit warmer outside here in Denmark
Thanks again
/ Andy
Old 27th March 2014, 08:53 PM   #1637
....and when it gets a bit warmer outside here in Denmark
Hi Andy 1967,
YW
What is "the right compression"?
That kind of weather will arrive soon...
Old 27th March 2014, 10:02 PM   #1638
Hi Andy 1967,
YW
Hi Djim,
Good question, but I am hoping that the right compression will have impact on the output and cone control. Except from bracing the mouth I recon this type of adjustment is all we are left with when the cab is glued
We are still below zero Celsius at night and short of a SPL meter
Old 19th May 2014, 02:08 AM   #1639
m R g S r is offline m R g S r  United States
Finally got a chance to drag these out. But only listened at very very low levels due to neighbors.
Old 19th May 2014, 02:09 AM   #1640
And I didn't have time to play around with the measurement mic, dark clouds started moving in shortly after so I was worried about rain (yet it never rained grrr)
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
