TH-18  Flat to 35hz!  (Xoc1's design)
Old 16th July 2013, 07:16 PM   #1381
sbjacob is offline sbjacob  United States
Originally Posted by NEO Dan View Post
Hi Pabesco,
I've not used the 18LW2400's but I do not think you will be disappointed, and they should do nicely for a "smaller" system. There are two routes you can go on wood IMO, one being quality plywood, and the other being something cheap like OSB. The middle ground of particleboard, MDF, and regular construction ply you should avoid altogether.
Quality plywood is or can be tough to find and really expensive, especially on an island. 13 ply Baltic Birch B/BB grade is generally considered the good stuff, but what makes it good is that there are no voids and the quality of the inner ply's is nearly as good as the outer surface you see. Baltic Birch is totally made of birch, not just birch veneer for outer skins.
BB ply:
The difference:
Both examples appear to be of good quality, but I would prefer not to buy the one on the left. Fewer ply's give a tendency to to warp and the thin outer veneers are easy to damage.
This is what you want to avoid:
The gaps due to voids or splices can make air leaks or rattle
There is some stuff called Auraco Ply that I tried on some monitors:
Click the image to open in full size. Click the image to open in full size.
It's OK if available, not great but serviceable. It's one of those that tends to warp, but it is generally void free.
If you are inexperienced in woodworking get help, you don't need fancy tools but you do need to be able to make clean straight accurate cuts.
No scoops
I agree on using good quality plywood I used Baltic Birch on my 4 DIY Klipsch WMW bass bin's on the horn section of the cabinet and Red Oak for the outsides.
Old 16th July 2013, 08:06 PM   #1382
Thats MWM Bass Bins I need new glasses
Old 16th July 2013, 11:44 PM   #1383
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Nice work, is that BB MDO ply? I've never seen that before...
Dan
Old 19th July 2013, 08:12 PM   #1384
Dan the inner part of the bin is Baltic Birch sorry not sure what you mean by MDO?
Old 19th July 2013, 09:12 PM   #1385
NEO Dan's Avatar
I've never seen MDO with a BB core...
Dan
Old 19th July 2013, 09:16 PM   #1386
The Red Oak plywood has about 10 plys
Old 19th July 2013, 09:55 PM   #1387
NEO Dan's Avatar
Lets try again...
Dan
Old 19th July 2013, 10:10 PM   #1388
Lets try again...
Yes not cheap it was about $120 a sheet it's twice as heavy as regular shop grade birch plywood.
Old 20th July 2013, 11:23 AM   #1389
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Your monkey needs a new prescription Dan.
Mark
www.kravchenko-audio.com
Old 20th July 2013, 12:32 PM   #1390
NEO Dan's Avatar
You off your meds again Chimpchenko?
Dan
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
