TH-18 Flat to 35hz! (Xoc1's design) - Page 129 - diyAudio
Old 24th April 2013, 02:51 AM   #1281
Fully active, horn loaded if you can afford the space. If not simple good components will do!
Midbass horns will be the largest, if they are straight horns.
I can't afford the space so I'm doing 2x15" BR midbass we, 8" sealed back midranges and 1" compression drivers. 4 way active.
Sub amp is class H and all 3 other amps are class AB
Old 2nd May 2013, 12:50 AM   #1282
I don't think I can really afford the space either (I'm guessing if I have to ask, then I probably don't). One of my worries is getting the 2, 3 and eventually 4+ pairs of tops to all integrate with each other nicely (no/very minimal phase issues, etc). So, I'm looking for a design concept that will have superb cohesion.
For some examples: I don't like those pockets of sound you get when some wedges are packed together and I don't want it to sound like the flanger is on when walking past the stack.
Old 11th May 2013, 11:13 PM   #1283
sbjacob is offline sbjacob  United States
Has anyone done a side by side comparison of the DIY TH118 and the Danley TH118?
Old 11th May 2013, 11:16 PM   #1284
Has anyone done a side by side comparison with the DIY TH118 and the Danley TH118 ? I have a pair of Danley TH115's and was thinking to build a few of the TH118's ? Thanks
Old 11th May 2013, 11:46 PM   #1285
No one has posted any such test on DIYaudio, but the XOC1TH18 is quite similar to the TH-115/TH-118 fold pattern and identical in size.
Old 12th May 2013, 10:43 PM   #1286
wg_ski is offline wg_ski  United States
Default Arauc-o-ply baby, in the tree top
When the jam breaks, the bass it will drop.
It's been a whirlwind 3 weeks building these TH18. I did a quick shootout against my old 40 Hz boxes to break in the new ones playing some Metallica before their first use. I was quite pleased with the results. Subjectivey, they seem every bit as sensitive and go a bit deeper than the front loaders they replace even though they model to the same 40 Hz in a quad. I was even more pleased Friday night. Really simple alignment - adjusted the delay to 8.5ms and actually took 3dB off the old setup. Cranked up the B&C's in the THs run STONE COLD, where the old boxes would get blazing hot on top and noticeably lose SPL over the course of 2 hours. Quite a bit more than equivalently-pushed labhorns, in fact.
Fortunately, I have some line arrays to build before I have to decide whether to build more of the same or look into bigger boxes using those same drivers.
They are really nice and easy to move around.
Old 12th May 2013, 11:22 PM   #1287
Zero D is offline Zero D  United Kingdom
@ wg_ski
Looking good & the wheels line up "quite" nicely inside the rear angle
Will you be posting any test graphs etc ?
Old 12th May 2013, 11:49 PM   #1288
BP1Fanatic's Avatar
How come the FLH's don't have mouth bracing?
Old 12th May 2013, 11:50 PM   #1289
Eventually. I've got a bunch of honey-do's that need attention before I dare break out the omnimic in the back yard. It may even be a while before I get to bondo, sand and Duratex them. The old ones and the tops are still unpainted.
Old 14th May 2013, 01:30 AM   #1290
Sweet build! 4 more coming soon?
Btw what did you use for the driver displacement correction? What compression ratio? I know you said they don't heat up, but how do they sound when pushed?
It looks like the box you have constructed is almost identical to the DSL TH-118. Yours has more reflectors and more bracing than the DSL box however
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 03:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 23rd September 2015 12:32 AM
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 10:22 AM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 03:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 08:38 AM
Copyright 1999-2017 diyAudio
