TH-18  Flat to 35hz!  (Xoc1's design)
Old 19th October 2012, 10:25 PM   #1171
kctess5 is offline kctess5  United States
I hope you continue with your measurements of the speakers you built. You will need to measure at a greater distance than 1 metre as you are maxing out your db meter!
I plan to take 10 meter measurements once all four are done and I figure out how to make my macbook use the Behringer sound card as input so I can use the SPL meter.
Of course the alternative is to fit a metal grille. but the bracing is an option for people who are not worried about party animals, or have no metalwork facilities.
I would like to do this but I have yet to find a source that would be cheap enough to do all 4 for a reasonable source. Any ideas?
135.7 db@ 1m
That's about what I model on my computer at the power I was running so that makes me feel good haha
Old 19th October 2012, 10:30 PM   #1172
mwmkravchenko is online now mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
You can get metal grill material from PE
And you can bend it over a plywood form if you use some simple metal forming principles.
Clamp it firmly to the form, and whack it with a soft faced hammer, a dead blow hammer is better. You need to notch the corners so that everything meets up correctly but it is not really all that difficult.
You just finished making a rather complicated box, what yah afraid of now?
Mark
www.kravchenko-audio.com
Old 19th October 2012, 10:35 PM   #1173
It's not the difficulty of it its the cost. If I remember right pe grills are like $50
Old 19th October 2012, 10:39 PM   #1174
Mark Kravchenko
Dayton Audio SG2230-6RFL Flat Metal Grill Pair 262-878
Mark
Old 19th October 2012, 10:46 PM   #1175
Xoc1 is online now Xoc1  United Kingdom
Xoc1's Avatar
I have a local grille guy, but he is over 5000 miles away from You.
Old 20th October 2012, 05:19 AM   #1176
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Hi Martin,
You have mail!
NS
Old 21st October 2012, 03:16 PM   #1177
noSmoking's Avatar
Originally Posted by Xoc1 View Post
Hi Nosmoking I tried to set out your dimensions for the throat mods but there is something that does not add up. The pic shows a 138 dimension but this seems to be wrong. Can you recheck and add some extra dimensions if possible. I assume the 112 flat piece is positioned central to the baffle cut out?
Xoc1
You are correct I swapped them,I used a templet to align screw holes when the side went on and that's were I got the measurements from I should have made a drawing,but impatient,lol.Sorry for the mix up!
NS
Old 26th October 2012, 12:53 PM   #1178
CRESCENDO is offline CRESCENDO  United States
I believe it was jbell who said that grill is quite flimsy. He recommended the Dayton square grill. This is what I'm using, along with acoustically transparent foam behind it to stop the 'ringing' of the grill and for an extra layer of drink-spill protection.
Old 26th October 2012, 12:59 PM   #1179
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Both are thin @ 1.2mm, if you want a stronger grille just put a curve in it.
Dan
Old 26th October 2012, 01:10 PM   #1180
Yeah, they are both thin. The square grill just seems to have a bit more material intact. The circles are pretty close together on the other grill - maybe that's the reason.
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 02:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 03:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 23rd September 2015 12:32 AM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 03:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 08:38 AM
Copyright ©1999-2017 diyAudio
