Old 30th September 2012, 06:58 AM   #1091
Originally Posted by djk View Post
" I have found some used Crest CA-9 and CA-12 amps for enticing prices"
How about $340 with free shipping, brand new.
Beach Audio has some that are 220V only at that price.
I don't see em: Beach Audio Crest Link
Hidden part of the site, maybe?
Wouldn't I need some sort of step down voltage transformer to make the 220V version work in the US?
Old 30th September 2012, 07:31 AM   #1092
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
No just a correctly wired outlet. These big amps you are looking at need/require a better service than the standard household outlet to make full power, especially at the duty cycle of your program material.
Dan
Old 30th September 2012, 09:21 AM   #1093
djk is offline djk
djk's Avatar
http://www.crestaudio.com/media/pdf/...ec_10-5-98.pdf
Crest Audio CPA900CG220V Crest Dj Amp 900w Into 4 Ohm | eBay
Candidates for the Darwin Award should not read this author.
Old 30th September 2012, 07:28 PM   #1094
NEO Dan's Avatar
http://www.crownaudio.com/media/pdf/amps/137435.pdf
http://www.crestaudio.com/assets/lit...6226_13000.pdf
Dan
Old 30th September 2012, 09:26 PM   #1095
Finding 220 outlets is difficult on many smaller gigs.
"Big amps" like the CA9 or 12 run fine off 20 Amp 120V Ac circuits found in standard commercial or current household wiring.
I run two Crest CA 9 (one bridged mono at 4 ohms) and a QSC PL 3602 (stereo 2.3 ohm operation) off a single 20 amp 120 volt circuit.
I have run double that off a single 20 amp 120 volt circuit, didn't find out all the outlets were the same circuit for several days until a miswired guitar amp popped the breaker.
The amps have never popped a breaker except when a CA 9 PSU capacitor shorted to ground.
Art
Old 30th September 2012, 09:33 PM   #1096
NEO Dan's Avatar
What are the top rails at in the CA9? I don't see this amp as a contender vs the PLX3402's as it's double the weight and no SMPS...
Dan
Old 30th September 2012, 10:22 PM   #1097
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
Now that would have been a bit of fireworks.
Most circuit breakers are capable of passing ten times their rating for breif periods of time.
I think you prove that in spades Art.
Mark
Old 30th September 2012, 10:25 PM   #1098
NEO Dan's Avatar
Looking more closely at the datasheet that CA9 is an amazing deal for the money, but I don't think I'd expect to get away with running multiples on anything but a beefy 220v service.
Dan
Old 1st October 2012, 02:39 AM   #1099
Yeah, I don't think we've ever had a gig with anything but 120V (15A or 20A) - with the exception of one gig last year off an MQ Power Whisperwatt generator.
So, I think I'd be more comfortable with 120V amps. I would, however, like to further educate myself on different power configurations (3 phase included) should the opportunity/conditions arise.
Old 1st October 2012, 02:49 AM   #1100
Before I click "Start Measuring" I clicked "Check Levels" to be sure everything was still even - yet, it popped up with "Level is Low" before audio was heard through the sub
So, the measurement process stops, but the 2 sweeps continue to play.
I get this dialog box (attached) before any audio is played
When I enter the SPL Meter for calibration, it supplies a filtered pink noise signal, not sine wave choice. When I enter the Signal Generator, it doesn't show an incoming signal, just outgoing and "RMS Level dB FS" adjustment. Where do I need to be and what do I need to do to get this done properly?
So, I tried REW again last night - re-calibrated the sound card as well (had a feeling it wasn't done properly and now the response looks less questionable).
Went through "Check Levels" and on to the generator. Played a 60Hz sine (at 2.83v w/cab disconnected), SPL meter & RTA mic next to each other, one meter from the TH. Opened up SPL reader in REW and clicked calibrate. My SPL meter read 104.7dB, so I typed it in and it said the highest I'd be able to measure is 99dB (instead of the 189dB it said before). Am I doing something wrong here? REW is now able to read SPL, so - that's a step forward at least.
Still, when I go in to measure, I click "Check Levels" there, it pops up the "Signal too Low" warning before any audio is played. Then, audio plays for a couple seconds and stops (same happens w/measurement sweep). Maybe I should set up a loop for REW to calculate for sound card delay option.
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 09:22 AM
18 inch labhorn design. mulletdude Subwoofers 21 12th November 2010 01:40 AM
Ciare 18 bass horn design soundhead Subwoofers 1 28th March 2010 06:51 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
Copyright ©1999-2013 diyAudio
