TH-18  Flat to 35hz!  (Xoc1's design)
Old 29th September 2012, 08:39 AM   #1081
CRESCENDO is offline CRESCENDO  United States
I tried that after some time and set it to 99dB (meter was at 1....meter) - "Maximum SPL with this calibration is 189 dB". Tried measurement again and got the same dialog box.
Old 29th September 2012, 08:40 AM   #1082
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Breaking things down to the input side I would go through REW SPL calibration and just use the REW SPL meter to verify the mic input is correctly receiving sound, your voice should register...
I'm tired, your on a Mac right?
You can also see the input in the Mac SysPref>Sound>Input there is a bar graph meter that will show input level for the device.
Dan
Old 29th September 2012, 08:42 AM   #1083
Originally Posted by NEO Dan View Post
Actually it seems odd that you could or would see input on the unconnected channel, the gain for the unconnected channel could be turned down IMO. Is the mono button or monitor button switched on?
My sound card nor digital console have mono/monitor. I believe the "L" input knob was turned down, but I didn't check. Nothing was connected to it.
I feel bad for flooding this thread with my REW problems
You don't happen to have AIM/iChat, do you?
Old 29th September 2012, 08:42 AM   #1084
NEO Dan's Avatar
this indicates the input sensitvity is set way low, turn it up till you are @ ~130 max. The mic is not good that high anyway.
Dan
Old 29th September 2012, 08:54 AM   #1085
Yeah, Mac. OK, I'll double check this weekend, hopefully.
Due to the amp set for 2.83v testing. I'll do this in the daytime then. But, I'm sure my neighbors would've loved a 130dB 60Hz sine at midnight
Old 29th September 2012, 09:02 AM   #1086
NEO Dan's Avatar
I'm sure this is the problem. You just need to turn the knob up on the mic input, no need for loud noises. 1-2v output is more than enough as you are simply calibrating the REW sensitivity/REW SPL meter to match your handheld.
Once this is set, you are SPL cal'd until the input knob is moved.
I normally don't have chat on in gmail. I sent you an invite, you are welcome to iMessage face time or call, but not tonight I'm about to crash it's 5AM on my end.
Dan
Old 29th September 2012, 09:11 AM   #1087
OK, I'll try it again. Thanks, Dan.
Old 29th September 2012, 12:47 PM   #1088
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Hi Crenscendo,
I am lurking,SO keep on talking REW,I am a nubbie with it and it helps seeing your solutions,
I built a better mic for mine based on wm-61A capsule,Digikey has them and
I used BC560 transistors, I have RTA measurements from 20 to 20K, Try here
Bill Wall's DIRECT APPROACH - Microphones ECM-8000 has the wm-60a in it ,
Have good day,It's raining in Texas,lol
NS
Old 30th September 2012, 12:06 AM   #1089
Looks like he turns a measurement mic into a vocal & instrument mic - interesting, but not really what I'm looking for for this purpose.
Old 30th September 2012, 03:23 AM   #1090
djk is offline djk
R.I.P
djk's Avatar
" I have found some used Crest CA-9 and CA-12 amps for enticing prices"
How about $340 with free shipping, brand new.
Beach Audio has some that are 220V only at that price.
Candidates for the Darwin Award should not read this author.
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
