#1061 | |
The SpeakerPower SP4000 option is fantastic. Maybe not ideal for my situation, but I was just looking for a high power plate amp w/XLR in for another project. Speakon out is a definite plus. Have you any experience with the Crown I-T8000? There's a sound engineer a couple hundred miles from me who switched to those from his PLX's. He runs (4) TH-118 off of one I-T8000 and reports much more LF content without the notes dying off quickly like his previous amps. Last edited by CRESCENDO; 28th September 2012 at 12:12 AM. Reason: found pricing |
#1062 |
Have you (or anyone else here) tried this?
Fighting For Power |
#1063 | |
Regards, Dan |
#1064 |
"It only works on certain types of amps and is tied to how the power supply is handled.* Amps with a sperate power supply for each channel will not generate any more power.
Yes it inverts the B channel with respect to the A channel.* And ties the B channel input to the A channel input.* This only works if you are sending the same signal to both outputs-which is not the case in stereo. So you would need 2 amplifiers with 4 loudspeakers hookedup to do this in stereo." -Ivan Beaver |
#1065 |
Not when the amp is actually built with an inverted channel, IPR series 1600's and 3000's for example.
Regards, Dan |
#1067 |
"It works and some amps are built like this from the factory now. "
It makes a fraction of a dB difference and can have a downside of dynamic woofer off-set going in opposite directions in a stereo amplifier. It has been tried in the past in many commercial designs, and then abandoned. It is touted as being a fix for power supply pumping in half-bridge class D designs, but that remains to be seen.
Candidates for the Darwin Award should not read this author. |
#1068 | |
One of the excellent features of the SP4000 is it's low frequency performance at really low impedances. I have used it with four Lab 12 in parallel, at Fb that is only a 1 or 1.5 ohm load, and the amp still kicked hard, though it would be possible to kick it's breaker if leaned on too hard for too long. That said, on paper the I-T8000 would have 3 dB more output in to a four ohm load than the SP4000, whether it would actually make a particular sub sound louder is a question only answered by an A/B test, my investigation of just four amps revealed large differences that don't correspond to specifications. Of note, the old school heavy metal Crown PSA 2 (weighs 8 times what the SP-4000 weighs), rated for only 460 watts at 4 ohms, and 700 at 2 ohms, put out 1 dB more output in to a BC18SW115-4 than the Crest CC 2800, rated at 965 watts at 4 ohms, and 1400 at 2 ohms, almost exactly double the paper rating of the PSA-2. |
#1069 | |
The prices for these amps have reduced a little bit due to new versions coming out. I saw the amp as a more powerful (yet lightweight) upgrade from what I'm currently running (DSP being a bonus). I have found some used Crest CA-9 and CA-12 amps for enticing prices - I just don't know how I'd enjoy quadrupling my rack weight :P The I-T8000 seemed a decent compromise. I'm loving the knowledge I'm reading from you all, so I'm not asking for that to stop
#1070 | |
![]() So, the measurement process stops, but the 2 sweeps continue to play. I get this dialog box (attached) before any audio is played When I enter the SPL Meter for calibration, it supplies a filtered pink noise signal, not sine wave choice. When I enter the Signal Generator, it doesn't show an incoming signal, just outgoing and "RMS Level dB FS" adjustment. Where do I need to be and what do I need to do to get this done properly? |
| 2 18 bass design | simpleacoustic | Subwoofers | 101 | 15th May 2011 09:22 AM |
| 18 inch labhorn design. | mulletdude | Subwoofers | 21 | 12th November 2010 01:40 AM |
| Ciare 18 bass horn design | soundhead | Subwoofers | 1 | 28th March 2010 06:51 PM |
| I want my Avalanche 18 to go flat to 15hz | thadman | Subwoofers | 10 | 11th November 2006 02:54 AM |
| Looking for suggestions on a 1300W Dual 18 sub design. | mjcohen | Subwoofers | 5 | 21st December 2004 07:38 AM |
