TH-18  Flat to 35hz!  (Xoc1's design)
Old 19th September 2012, 10:43 PM   #991
Djim is offline Djim  Netherlands
Hi Martin,
Indeed those imaginary corner lines seem to line up very well, thanks for the visualisation.
Old 19th September 2012, 10:59 PM   #992
grec13 is offline grec13  United States
Hi guys.
It seems that DSL used not only cone correction but some kind of "V" throat. (post 841)
Or I'm wrong?
Sergey
Old 19th September 2012, 11:08 PM   #993
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Originally Posted by Xoc1 View Post
Hi Djim
I don't see the different shape being a problem.
The difference from the centre to the sides changes as the volume we are accounting for is round and the cone correction is linear. The 3 lines I have simplified it to are just an approximation to enable the opposing shape to be built in timber.
If you look at this screen grab you can see that the lower cone correction line representing xmech having a wider flat face actually still represents a fairly linear path to the opposing timber built cone corrected throat.
An imaginary line drawn thru the imaginary corners seems to line up quite nicely!
Martin (Xoc1)
Hi guys ,
Have I got this correct,The above diagram is about the same as adding pieces of wood beside the stub,so if that's correct then could you make some optimal measurements for me to make one ,I would have to guess at them at this point ,and should they be circular or straight across as the stub is now?
I have a 500 watt amp ,I set the hpf at 36hz,I am using a DCX 2496,
NS
Old 20th September 2012, 12:44 AM   #994
Hi noSmoking,
The Stub+Disk method is for existing models of the Xoc1-TH18. The "diagram above" is for a new TH18 that has a different lay-out.
Old 20th September 2012, 05:13 AM   #995
noSmoking's Avatar
Hi Djim,
I see what you're saying I'll try the disks for now,
Thanks,
NS
Old 20th September 2012, 03:31 PM   #996
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by grec13 View Post
Hi guys.
Or I'm wrong?
The DSL TH-118 uses a "V" throat (no other "cone correction" per se), similar in concept to post #528 figure 3, go back to post 528 to see a crude example of how it is implemented.
Old 20th September 2012, 05:07 PM   #997
tb46 is offline tb46  United States
Default Simple Cone Correction
Here is an example of what I would call a simple cone correction:
Oliver
Old 20th September 2012, 05:47 PM   #998
Hi Oliver,
That corresponds more or less with the Disk method. Most people find 2 disks of 18mm as 'enough' for existing TH's.
Old 20th September 2012, 06:43 PM   #999
Hi Djim,
"...That corresponds more or less with the Disk method..." I agree, at the wavelength in question the differences just don't matter.
Oliver
Old 20th September 2012, 07:10 PM   #1000
ODougbo is offline ODougbo  United States
Still lurking and the 1000th caller.
TH-18  Flat to 35hz!  (Xoc1's design)Hide this!Advertise here!
2 18 bass design simpleacoustic Subwoofers 102 20th July 2017 01:38 PM
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
