Hey People
I just finished making the outside of the box some glued and some screwed so i can still do inside work, and ive made the mounting holes, just need to add bracing and the port ... My question, Ive used winisd and Ive used it multiple times with subwoofers. It wants me to have a port length of 82 cms, which is fine just wondering how much shorter i can make it to be effectively make it 82cm? cause the port uses the bottom and left side of the enclosure meanings its in the bottom left corner Ive read that when using 1 side that you subtract the height of the port to the length of the port. Also some more information. it runs across the bottom and up the back wall and depending on how long its actually got to be maybe along the top in the same plane. The internal dimensions are 35cm x 35xm x 55cmx Thanks |
#2 |
Bump lol, I want to make the port tomorrow
#3 |
Previously posted by 'bjorno' IIRC:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
haha I found that while browsing the internet last night in bed on my ipod
#5 |
entering the value there 1.728 makes the port longer cause when i entered it it makes the port go from 82 to 89 or am i meant to meant to play with it so it becomes 82 when i enter that correction value...also ive noticed that as soon as i type anything in there it adds length, the same length
#6 |
There is no bloody way to calculate the length of a port correctly just based on theory.
Only in an itterative process of calculation and measurement you will know for sure what the tuning is. If you don't have measuring equipment, use the pea method. Lay the prototype on its back and put a dried pea, or some grains of rice, on the woofer. Do a sweep, and the frequency where the pea (or grains of rice) move least, that is where your Fm is. |
#7 |
Thank you for posting the picture containing an incorrect formula! I take the opportunity to update again Another revision:b |
| Min. port clearance to side walls? | ro9397 | Multi-Way | 3 | 4th November 2010 03:46 PM |
| port length | tald | Multi-Way | 7 | 14th January 2010 01:26 PM |
| Slot port. Using cabinet walls. How to correct? Help! | tarnationsauce | Subwoofers | 3 | 22nd July 2005 08:53 PM |
| making curved walls thin | paulspencer | Subwoofers | 2 | 10th December 2004 06:59 AM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.08588 seconds (83.33% PHP - 16.67% MySQL) with 11 queries |
