Back at it again!. Here is my first monster tapped horn subwoofer build!
Original plans were from this thread over here at diyAudio lab12 TH. Plans were meant for a Lab12 but a quick check with HornResp showed that my Dayton worked equally well. 97db/watt @ 25hz in 1.0pi space, and 94db/watt @20hz!! ![]() Didn't take too many pics but here are a couple.. ![]() Test fit of the top. ![]() 1.5 litre bottle... ![]() ![]() Kinda messed up a cut here but i fixed it. Works alright ![]() ![]() Beautiful ![]() To the left is my rathr intereting "Franken-Box", and the right is the monster of course! ![]() Tall beast! ![]() The Dayton inside ![]() My phone compared to the opening :rubeyes: ![]() Nicely hidden. Man, this thing is HEAVY! ![]() The TH is crossed over at 55hz @24db/octave to my 2 6.5" t-line midwoofer which is then crossed at 100hz @24db/octave to my sats. Listening impressions: Sounds wayyy cleaner than the ole ported box. Some songs sound "different"? Can't really explain it but the TH lot will know what i mean. Only have about 50 clean watts going into it at the moment. Even then, its still plenty loud! One question, how significant do little air leaks inside affect the response/performance of the TH? I stuck my head into the port (yes it hurt a little) and heard a slight wooshing sound. Skeptical that it might be the piece right in the middle... Comments appreciated! Cheers! |
#2 | |
I found when building my first tapped horns that they weren't great until I sealed the driver to the wood (used foam weather-proofing strip), and sealed the removable back panel. The performance was such that, using a 25w tripath amp, at full power the leaky one struggled to give much output at all. What did come out was ~80Hz midbass. Sealed everything up properly, and extension is down to 25Hz, and goes louder than I need. If you're worried about internal leaks, plot the impedance curve of the TH, compare it to the sims. I'm glad I'm not the only one that's just run cable into the mouth. I do have some speakOn connectors somewhere, though... ![]() Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Question: What sub are you running? Big ave
#4 |
hows your back?
respect for being another one of us bass lunatics yes, leaks matter. a lot. |
#5 |
@chris661, Yep, i decided to move the TH out to check for leaks and i was right! There was a lil gap on the middle piece. I siliconed the gaps as far as i could reach then with an old antenna to reach the ends
. Should be sealed nicely now but im still waiting for it to dry. How exactly do I plot the impedance curve? Hey, we do get somewhat lazy at times. I've got some nice speaker terminals but no soldering iron at the moment... @big ave, My sub is in the thread title! Its a Dayton SD315-88 12" that I bought from PE early this year. @60ndown, Pretty good I would say, since I'm a 17 years old . Alright, will see how my sealing efforts work out tomorrow... Last edited by killa12222; 9th June 2011 at 02:39 PM. |
#6 |
Hey, another teenager!
There's a lot of ways to measure speaker impedance. You will need a decent multi-meter. There's a lot of tutorials on Google that will go into details, but a known resistor of, say, 2 ohm will be needed. And download winISD for the signal generator function. Your computer will become the signal generator. You might need an amplifier to make the signal a bit louder, but a decent headphone socket will drive the set-up well enough. Chris PS - I did install the speakOn connectors, for my tiny little tapped horns...
#7 | |
#8 |
Ok. So the enclosure is all sealed now and with foam tape around the drivers (i forgot that before). I did some quick before and after tests and wow this thing is a heck louder than before, even thought its sitting in the middle of my room! More testing soon.
@weltersys, Thanks for the tip, but i couldnt find any latex paint at my local hardware shop... @chris 661, yeah i'll test that out sometime soon but im pretty happy with it right now |
#9 |
WOW dude, that looks awesome. Let us know when you have a SPL reading.
Have you thought about using reflectors on the folds closest to the center? It might bring down the total SPL a dB or two but it should lower the frequency response considerably. |
#10 |
Whew been busy lately but here is a video of my TH for you all to have a listen
In the video, there's also a SPL reading using REW and a Behringer C-1U mic. Running only with approximately 1watt!! ((1.7v*1.7v)/3.1ohm) Youtube!! @johnB23, Thanks for the tip but I don't think its possible reach into the middle folds since the whole thing is screwed and glued
| Volvotreter 20Hz Tapped Horn build (pics) | RadiantNRG | Subwoofers | 60 | 12th March 2011 07:18 PM |
| two sd315-88 in a sealed box | arjen | Subwoofers | 4 | 26th September 2010 02:01 PM |
| Dayton SD315-88 12" - DVC310-88 12" | nixtux | Subwoofers | 3 | 2nd April 2010 05:49 PM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Dayton Classic 18" DCS-450 - Tapped Horn? | dolinux | Subwoofers | 15 | 4th December 2009 04:38 AM |
| Page generated in 0.12593 seconds (82.02% PHP - 17.98% MySQL) with 10 queries |
