Old 3rd June 2011, 02:18 AM   #1
justint is offline justint  United States
Smile 10" horn 3cubic feet help!!!!
Need help making as loud of a sub box I can with at least 115db @37hz .. Now here is what I got to work with... Box can only be 28" tall by 12x18" I am thinking use a 10" or 12" or 2 of em What ever you feel is for subwoofer and box style.. I got a $500 limit but less is always better
Old 3rd June 2011, 11:06 AM   #2
djk is offline djk
djk's Avatar
Candidates for the Darwin Award should not read this author.
Old 3rd June 2011, 11:17 AM   #3
djk is offline djk
djk's Avatar
Ciare NDC8-3, about $200, with 50W is 115.5dB at 37hz with 20V input (50W/8Ω). Rated for 300W RMS, it should play loud enough.
Rises about 3dB from 40hz~100hz to allow for 'room gain', -3dB around 34hz with respect to 40hz.
Old 3rd June 2011, 02:01 PM   #4
Can I get this sub in the u.s. I haven't heard of that name brand ?
Old 3rd June 2011, 02:26 PM   #5
looks promising. as long as its in 1.0Pi...
Old 3rd June 2011, 09:04 PM   #6
djk is offline djk
djk's Avatar
"Can I get this sub in the u.s. I haven't heard of that name brand ? "
A quick Google comes up with:
Ciare NDC8-3 - Ciare NDC8-3 is a 600 watt 8 inch lightweight neodymium speaker for all bass and mid-bass speaker systems- Ciare Speakers - Ciare NDC8-3 8 inch lighweight neodymium speaker for bass guitar, PA speaker systems, etc. Ciare NDC8-3 8 inch
"looks promising. as long as its in 1.0Pi... "
Most people have a floor and a wall to use it by. They may not have a suitable corner though, so I didn't use 0.5Pi.
Old 3rd June 2011, 09:40 PM   #7
jbell is offline jbell  United States
Here's a cheap eminence suggestion that works assuming 1pi is OK.....
Old 3rd June 2011, 10:36 PM   #8
Here's a ppsl, just for djk that would accomplish your stated goals... and at $59 each, would be cheap, and have budget left over for a bash500 to power it...
Old 6th June 2011, 04:19 PM   #9
Jbell thanks for the research . Which one would you suggest.. It's going in a boat ?
Old 6th June 2011, 06:30 PM   #10
You won't get 1pi loading in the boat -- 2pi only. You replacing your dual kicker TH? or are you helping a friend out -- those sound like different dimensions than I remember for your dual kicker. what wattage/ohm you targeting?
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
2 way with HF horn and 10-12" LF AudioGeek Multi-Way 44 2nd February 2011 06:40 AM
Single 8" or 10" Tapped Horn that can play 20-80Hz maxjr Subwoofers 12 16th January 2011 07:25 PM
10" 15hz Tapped Horn jblauvelt Subwoofers 11 7th January 2011 02:36 AM
30hz 10" tapped horn magic? killerfishes Subwoofers 10 27th December 2009 05:53 AM
Page generated in 0.09644 seconds (78.70% PHP - 21.30% MySQL) with 11 queries
