Looking for input to selecting Subwoofer cabinets. My band plays Reggae Rock and needs alot of low end and deep bass for the bass guitar and kick drum.
I want to use a 2X18 or 2-1x18 cabs i have narrowed it down to these and would appricaited any and all input. Thank you! #1. Yamaha cw218v- reflex, folded 2x18 1220 watts rms range: 30hz-2khz $730 #2. 2 1x18 seismic P.A. Bass subs- 500 watts rms(each) range: 20hz-5khz $470 total #3. 2 1x18 seismic empty cabs with 2 eminence sigma pro 18" driver- 650 watts rms(each) range: 41hz-2.4khz $680 total #4. 2 1x18 seismic Enforcer II sub cabs- 1000 watts rms (each) range: 45hz-2khz $580 total #5. 2 1x18 seismic DOWN FIRING sub cabs- 500 watts rms (each) range: 20hz-500hz. $460 total or... #6. 2x12 cab 3.5 ft3 loaded with 2 eminence lab12 drivers? $435 (coulnt find the eminence lab 12 drivers on WinISD, help!) Is there a difference if its down firing or not? Im just playing a four string for now but might use a synth through it as well, any comments or advice would be helpful Thank you! |
#2 |
Any Help or opinions ??
#3 |
Without any real specs on the Seismic product, I would have to choose the Yamaha.
The Lab 12 woofer is good in a big horn, not so good otherwise. Speakerplans.com ![]() Speakerplans.com The driver is normally $389, on sale for $219: P AUDIO_SD18
Candidates for the Darwin Award should not read this author. |
| Page generated in 0.07205 seconds (70.17% PHP - 29.83% MySQL) with 9 queries |
