Old 30th May 2011, 12:28 AM   #1
nuconz is offline nuconz  United States
Default Which TH sub design for older JBL woofers?
I have some older JBL woofers: E145 and the 2225H. All are 8 ohms.
Don't like the cabs they are in and want to make something stackable like the Cubo, SS, 3015lf, Tham 15, C/E/X PA, etc. but don't need anything like 140 db SPL.
Would like the LF response to go as low as possible, but certainly tuned to around 30 hz or so. Both have low Qts and decent Xmax.
What is the "best" for this HT/Hi-Fi? Don't want anything 6 or 7 feet tall. 5 feet might be ok.
Thanks for any input!
http://www.jblproservice.com/pdf/Thi...Parameters.pdf
Old 31st May 2011, 04:24 PM   #2
My 2 cent:
If you truly want 30 Hz, which I think is a good choice, at the moment only Cubo Sub will do from the Cubo series and will work with both drivers. AFAIK, the Single Sheet and other Cubo's are strictly 40 Hz plus.
The THAM 15 is an interesting choice, it's more a 35 Hz and up bin IIRC but is small and again IIRC will do 30 Hz and up in 1,0 pi.
There's some nice designs in the C/E/X PA thread, though I haven't had much deeper look into those models., other then the basic design from Xoc1, which simulates very close to Cubo Sub.
The THAM15 and Xoc1's both seem to favour low Qts, low Vas drivers.
Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 31st May 2011, 04:51 PM   #3
Originally Posted by Rademakers View Post
My 2 cent:
Best regards Johan
thanks much for the response. it didn't seem to be much of a "hot topic", which is surprising since there must be a few folks out there with some older JBL/Altec drivers that want a more "modern cabinet".
i also thought about modifying the Shadow SD12 cabinet for these drivers, but didn't know quite how to go about this. however, i found the following link that might give just what is needed. i can use the outer cabinet dimensions, omit the labyrinthine turns behind the woofer, and size the port in the same manner as in the Shadow but for these drivers, tuned to 30 hz and dump it into the scoop.
should be interesting. and i do like the Cubo sub. i want to be able to stack or group enclosures that give good solid bass response and don't weigh over 100#.
http://horn.hebfree.org/jbl/pdf/rearhorn.pdf
here's another interesting one. instead of using the KEF driver, use a single JBL and put one bend in the enclosure making it about 48" tall. not pushpush and nothing complex here. similar to a BiB but not so tall and should give solid bass down to about 30hz.
http://homepage.mac.com/planet10/TLS...map-041107.pdf
Dayton RS225, JBL Gold 12" Woofers johnmark Swap Meet 1 11th December 2008 04:06 PM
FS - JBL 2268HPL - 18 Inch Woofers - Brand New (Australia) Rialb Swap Meet 2 5th February 2008 09:14 AM
fs jbl horns -drivers and woofers HYDEBEE Swap Meet 0 15th August 2006 07:49 PM
older JBL drivers VS S.S ,LPG.vifa,ETC. tyler jennings Multi-Way 1 19th November 2005 12:25 AM
cabinet suggestions for dual 15" jbl woofers djquick_silver Multi-Way 4 24th September 2002 06:56 AM
Page generated in 0.09462 seconds (74.50% PHP - 25.50% MySQL) with 10 queries
