Hi All
Opinions sought... I am rebuilding my system with a view to new subwoofer options. 1 of Peerless 835017 XXLS sub vs 2 of Dynaudio 30W54 12 woofers in an isobaric configuration (already built- just finished prototype box 140 litre ). The dynaudios had been sitting around for some time unused. The dyns are rather nice and tight and deep, but maybe a little lacking in ultimate volume.-esp explosions etc. (when I say ultimate volume – its more than enough to annoy the wife and teenage kids...) I haven’t procured the peerless as yet but it may be available at a reasonable price. In WinISD they both have similar projected responses but the xmax of the Peerless is way above the Dynaudio. Anyone care to offer a comment on the Peerless driver – it seems to appear in car audio discussions frequently and wonder if it good enough for home (music and HT ) use Thanks in advance George
george a |
#2 |
do you really mean isobaric? Push pull seems more likely for a 140 litre box.
#3 |
well it's two drivers face to face , 25mm between them (clam shell?) and wired in parallel and reversed polarity- both move same direction on application of current.
push / pull ? - could be described as that i suppose Pardon my ignorance- which i have worked hard at achieving cheers george
george a |
#4 |
you are correct. that's isobaric. push pull is a little different. The drivers are wired the same as isobaric but are not face to face. see attachment
#5 |
The XLS is an all-around better woofer than the Dyn. You'll be happy with the switch.
#6 | |
b |
#7 |
Thanks to you all for your replies.
I will go over the curves and diagrams ....very impressive Cheers from downunder eorge
george a |
| Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? | IG81 | Multi-Way | 3 | 4th February 2010 02:48 AM |
| Peerless 12" XLS and 2 x 12" PR's | muhy3 | Subwoofers | 2 | 20th May 2008 03:38 AM |
| Dynaudio vs. PHL: Which 12'' would you use? | leifislive | Multi-Way | 0 | 12th November 2007 01:29 PM |
| Peerless XLS 12 in Melbourne | Sheld | Subwoofers | 12 | 17th November 2005 12:51 PM |
| Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? | tktran | Subwoofers | 2 | 14th August 2005 02:04 PM |
| Page generated in 0.07950 seconds (79.30% PHP - 20.70% MySQL) with 11 queries |
