R evenge C omes  with F orce
Old 31st May 2011, 03:36 PM   #21
Djim is offline Djim  Netherlands
Originally Posted by epa View Post
hi djim
group delay and impulse look verry good,at least in the sim.
i added a chamber to damp the out of passband peaks a bit.
still think you need a power plant to get to the max of them
I like your explanation "at least in the sim". The trouble is not the sim, but the reality of surface versus panelflex and keep everything in transportable weights. A 700liter cab is going to be quiet heavy with all extra bracing...
And since the request was 35Hz and he has only 2000W per channel it sounds more interesting to use double 18's and get more SPL from it.
Old 31st May 2011, 03:43 PM   #22
olsound is offline olsound
Which 18 do you have in mind
The rcf price is $500.00
Old 31st May 2011, 03:54 PM   #23
Even cheap ones can beat your RCF with just 2000 watts. Like Epa said you'll need a serious power plant cause your 2Kw is just going to 'tickling' the 21"
Look for 18" (8Ohm) with an Fs of <35Hz and a AES power rating of at least 700Watt continue and Xmax of > 7mm.
Or 18" (4Ohm) with an Fs of <35Hz and a AES power rating of at least 1200 Watt continue and a Xmax of >9mm
Old 31st May 2011, 04:45 PM   #24
Thanks for the info I wil keep it in mind
In the future I will invest in a more powerful amps for the rcf.
If you want you can assist with this project your knowledge is welcome.
Old 31st May 2011, 05:01 PM   #25
epa is offline epa  Netherlands
first ruf sketch
Old 31st May 2011, 05:18 PM   #26
Which 18 do you have in mind. The rcf price is $500.00
You seem to worry about 130$ difference between 2 x18"drivers over one 21" while you don't have a problem investing several hundreds to thousand$ for an heavier amp
(Ah, I see the 'Epa folding style' is returning )
Old 31st May 2011, 05:59 PM   #27
first ruf sketch
That look good,anymore up your seleve
Old 31st May 2011, 07:30 PM   #28
i have a moddeled a lot.
you sugested to go for the symetrc aproach.
if you click my nickname>find more post from epa,you wil find many more .
if you find a model that you like i can scale it up to your likings.
start here or here f.i.
Old 31st May 2011, 07:40 PM   #29
first ruf sketch
This one is ok
Old 31st May 2011, 07:47 PM   #30
i got a long free weekend coming up.
if u like this model i can work it out in detail.
how are your "skilz" ?
R evenge C omes  with F orceHide this!Advertise here!
Copyright ©1999-2017 diyAudio
