I was looking at these, and while they appear to be PA style higher efficiency low x-max speakers, they... aesthetically look really nice
For anyone who knows about these, can you maybe let me know if they're decently linear past x-max (x-mech seems to be five times as high) and whether they're even a decent value (at $325 I don't really expect them to be). I can't think of a home use of such high fs subs but it might be great in a car environment unless i'm mistaken; while the impedance is a bit high for a car amp the sensitivity seems relatively pretty good. Not sure if I`d really pay three times as much for these over something like a Peerless XLS but it is tempting. Last edited by RockLeeEV; 18th May 2011 at 04:32 AM. |
#2 | |
they where primarely used for pa stuf. the idea for the radial design is ,that the heat from the driver is radiated ouside the box. the quality is medium i'd say. the 12 inch dual concentric sounds reasenable. the 15 and 18 inch i heared in pa setup,they worked good ,but i was certenly not impressed by them. they have(had i should say) alu vc former. no flat or square windings. freq range is a bit limmited due to the frame in the center. they can move a lot past x-max whitout obvius distortion. whe had the 18 inch to about 4 cm peak/peak with audible distortion. cant realy compare because i never heared the peerles regards erik Last edited by epa; 18th May 2011 at 06:01 PM. |
#3 |
" unless i'm mistaken" -> yess you are.
#4 |
| FS: VOLT 12" RADIAL--one only, used | makingmoney | Swap Meet | 1 | 7th June 2011 03:01 PM |
| 15" Volt Radial R3803 (£100 for pair) | ShinOBIWAN | Swap Meet | 2 | 17th May 2008 12:08 AM |
| Panasonic Radial vs Blackgate Radial Caps | blindtiger | Parts | 1 | 11th March 2008 01:21 AM |
| 15" Volt Radial Drivers F/S | ANDYLASER | Swap Meet | 4 | 28th June 2006 11:38 AM |
| For Sale: Volt 12" radial studio woofers NIB | Bill F. | Swap Meet | 6 | 11th March 2005 06:31 PM |
| Page generated in 0.10741 seconds (78.74% PHP - 21.26% MySQL) with 10 queries |
