What do i need?
Hey!
I've been planning for long to fill up the lower regions. Currently i have a pair of Mar-Kel70 speakers powered by a Harman Kardon HK3490 amp. I want a woofer that integrates well with my EL70. I want to be able to play somewhat loud, i have a Reckhorn S-1 active 24db/octave XO. I don't need to play deep bass, maybe a little deeper than me Mar-Kel70 go. But i'm mostly after a little more headroom and cone displacement to get the real "thump" in rock music. My room is approximately 3.5x3.5m. My speakers are placed at a wall which is around 2.6m wide i think. On the right side there's a corner, on the left side is a door. So i will get some room problems. My budget is maybe $240 per channel, amplifier excluded. But i'd still like recommendations on what i could power the woofer/woofers with. $400-450 for the amplifier. |
i have this self powered subwoofer , has tight and powerfull sound :
JBL - ES250P - 12", 400-watt RMS (700-watt peak) powered subwoofer |
this sub works in the 35-150hz range , i use it because the low end of my system was lacking.
I want to XO at maybe 250Hz, so i'd most likely need one woofer per side. Placed somewhat close to my EL70. |
You can have them from byggdinbas.se and costs about 1500 SEK a piece. I don't know what that translates to in USD, but I am quite certain that it is quite a bit less than over here. |
I know of the sdx10 but it is a subwoofer and not a woofer. For the deepest bass I got some other subs at home if I'd like.
And I suppose the sdx10 wouldn't like to be crossed over at around 200-250Hz. |
| All times are GMT. The time now is 08:29 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
