Old 16th May 2011, 09:16 PM   #1
Aetius is offline Aetius  United States
Default Newbie Question(s)
I recently took a speaker design class and ended up with the following pair of bookshelf loudspeakers. They're built with one Dayton RS-150-8 and one Dayton RS-28A-4 per box and have the response curve attached.
The next logical step would seem to be to build a subwoofer. Ultimately the system will mostly be used as L-R-Sub for TV and movie watching, with music occasionally thrown through the system. I'd also like to build it with room to add a center channel and two back surrounds if I so desire, but have no immediate plans to do so.
I'm pretty much looking to build a moderately priced subwoofer that'll get decent bang for the buck that'll complement these bookshelves. I almost never blast sound, so as long as they can provide decent volume power isn't a big issue. That being said, I'm at a bit of a loss as to where to begin. How to select the right driver, plate amplifier and so on; any special things to be aware of in box design and construction.
sidenote: I don't have an amplifier yet, so in that regard the system can be designed for any amplifier within a reasonable price range.
Old 17th May 2011, 01:13 AM   #2
revboden's Avatar
what SPL range do you want? how much room do you have for a box? how large is the room?
Old 17th May 2011, 09:50 AM   #3
The bookshelves are rated at 86-87 dB, and when I tested them the other day they were providing plenty of volume without pushing the receiver very high, I'd probably be looking for a subwoofer in the same range.
The room is as yet unknown. I'll be building these when I have some free time this summer while job hunting, and the job I get determines where I live and so on.
Subwoofer size is flexible, something under 2 feet cubed would be ideal, probably closer to 1.5 feet cubed.
Old 17th May 2011, 04:56 PM   #4
chris661's Avatar
Some more questions.
How low do you want this sub to go (a decent pair of headphones can give you an idea)?
And would 2 subs be out of the question? Having stereo (or dual mono) subwoofers flattens the in-room response considerably, due to a more even excitation of the room.
Can you measure the SPLs you listen to at listening position? Alternatively, any ideas how many volts the speakers see? 2.83v at 8ohm = 1 watt (per channel).
So for a pair of speakers each receiving 1w, one speaker at 1 watt = 87dB. 2 speakers at 1 watt between them = 90dB. 2 speakers with a watt each = 93dB.
All those figures are much louder than one might think - I've seen recommendations of >100dB @1w speakers for a low power valve amplifier (this would be 106dB with each channel seeing 1w). Though 90dB continuous will permanently damage your hearing.
Personally, I'd get a couple of decent 10" drivers, give each a sealed box and eq to ~30Hz. Frequencies lower than this require lots of air movement. 40Hz is an easier goal, and would be easy enough with a pair of 8" drivers.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Newbie Question, Christian Solid State 3 15th March 2002 06:55 PM
Page generated in 0.08164 seconds (72.33% PHP - 27.67% MySQL) with 11 queries
