Speakerholic
Hi guys, they are at the other place and I would like to keep going with the project. Just the baffle cut out size for front mounting, no rebate.
TIA. |
#2 |
#3 |
Hi Cal,
What are you up to now? I've got a pair of the Extremis 6.8's that I should use one of these days. (BTW: I won't be offering any advice after our "adventure" in driver cut-outs last Summer!) Best Regards, Terry
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application Last edited by TerryO; 15th May 2011 at 01:05 AM. |
#4 | |
Speakerholic
#5 |
Speakerholic
Hi Terry,
After building this little beauty for my wife... Coming soon to a thread near you... ...I decided to build something a little more manly. You know, Cal style. Something that takes more than one person to move. Big Boombox |
#6 |
Cal,
Is something wrong with the data sheet that was linked? The "B" dimension of the drawing shows 147.0 mm (5.79 inches) for the under-flange measurement. Best Regards, Terry
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application Last edited by TerryO; 15th May 2011 at 02:03 AM. |
#7 |
Speakerholic
Does that coincide with your drivers? Just want to make sure. Measure twice, cut once you always told me
Thanks if you have the time Terry. |
#8 | |
I'll see if I can find something. Best Regards, Terry
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#9 |
Well, measuring mine, I get 5-13/16" [14.76375 cm] with just a little wiggle room as measured using a large metal worker's vice , so it's what I will cut mine if I ever get a chance.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. Last edited by GM; 15th May 2011 at 02:37 AM. |
#10 | |
You now owe Greg a few of those Canadian Brews! "A friend in need, is a friend indeed!" Best Regards, Terry
| cut out size for for Dayton ND20FA 3/4" tweeter? | Greybeard1 | Full Range | 7 | 16th August 2008 01:03 AM |
| Looking for Extremis 6.8 | nelsondog | Swap Meet | 0 | 13th October 2007 01:41 AM |
| how do i cut sonotube and keep the cut straight ? | zuki | Subwoofers | 27 | 11th July 2006 05:12 PM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| Page generated in 0.10365 seconds (78.23% PHP - 21.77% MySQL) with 11 queries |
