Old 10th May 2011, 05:25 PM   #1
Default Newbie w/ 18 ......need guidance
Ok so I DJ quite a bit. I had a friend of a friend give me a B&C 18PS76 http://www.bcspeakers.com/CPD/produc...?id=0000000053 . They used them in a few folded horn applications, and I guess had an extra. I'm looking to possibly use it as a sub in my set-up. I'm looking to build a box for this thing, but after doing some calcs I was getting an f3 of around 80 hz on a ported box tuned for 39 hz. Seems too high for a sub application. I need your help and suggestions. I wouldn't be using it in any large venues or large outside spaces, mostly in homes,small halls, backyards....etc. I do have the benefit of having it hooked up to my eq at all times.
Old 10th May 2011, 08:26 PM   #2
49 - for the 16th time
c2cthomas's Avatar
From messing around in WinISD I can only get it down to around 40Hz clean - and that takes a 12 cubic ft. box with two ports. B&C makes a quality product - but this one is a big woofer for pro sound but I don't see it working as a sub-woofer. There are others around that know a lot more than me (like the 8 year old next door) - but that's my read on it. Looks like we are in agreement with each other.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 11th May 2011, 12:41 AM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Try learning HR instead: A T-TQWT less than 7 cu.ft and a f-3dB about 30 Hz:
b
Old 11th May 2011, 06:45 AM   #4
umm why not use the driver in the same application that your buddies used them in?
Old 11th May 2011, 10:09 AM   #5
Originally Posted by B3NNY View Post
..I'm looking to possibly use it as a sub in my set-up. I'm looking to build a box for this thing, but after doing some calcs I was getting an f3 of around 80 hz on a ported box tuned for 39 hz. Seems too high for a sub application. I need your help and suggestions... backyards....etc. I do have the benefit of having it hooked up to my eq at all times.
Hi B3NNY,
Here's an another approach you can test: Modifying the Qts by inserting a series resistor that would increase the driver Qes thus push up Qts a bit.
Of course you could use your Eq too but the precision wouldn't be as accurate but the end result would be very similar...PA-sub(SQ):
b
Newbie looking for some guidance. frozen001 Class D 2 3rd March 2010 05:18 PM
tube newbie needs guidance MoxMonkey Tubes / Valves 20 30th June 2008 06:24 AM
Newbie Guidance... Paprika Solid State 22 13th February 2004 07:16 PM
FS: Plitron 225VA 18-0-18 Shielded Toroidal Power Transformers planet10 Swap Meet 3 10th August 2002 11:52 PM
Page generated in 0.08135 seconds (73.99% PHP - 26.01% MySQL) with 11 queries
