I have RCF L18P300;Thiell small parameter : Fs 33 Hz , Re 5,0 Ohm , Qms 8,3 , Qes 0.34 , BL 23.5 , Mms 180 gr, Vas 226 liter, Sd 0.113 m2 , Xmax 7.8 mm , Le1k 1.9 mH , Eff 2.3%
I want to use this driver for subwoofer for FOH indoor and outdoor; please give me suggestion for optimum subwoofer box type and dimension! thanks |
#2 |
Candidates for the Darwin Award should not read this author. |
#3 |
Hi, DIY?
b |
#4 |
or a th like in this topic
works good with your woofer to |
#5 |
The Cyclops is also a TH, but with extended midrange.
#6 |
thanks for the suggestion, btw how to check the response of the unit after finishing the box! what do I need to measure the response? is Phonic PAA3 can be use to check the response? thanks
#7 | ||
he ever told me he was a real diy LOL
*out of the past=out of the future=in the present time+ing* Last edited by Thawach; 12th May 2011 at 11:06 AM. |
| In Bass reflex box (vented)-If I make smaller box than what consequences will I have? | eliaselias_0 | Multi-Way | 6 | 3rd January 2011 03:49 PM |
| Aperiodic box for B200. Vent size and box shape? | ChuckT | Full Range | 11 | 15th October 2006 07:29 AM |
| Want to re-box several si t amps in one box. How do I hook up to one power supply? | ExJxC | Class D | 7 | 22nd September 2005 09:27 PM |
| Box Design/Make me a Box Focal 5WS | arnach | Car Audio | 5 | 13th December 2004 06:56 AM |
| High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 | PTSOUNDLAB | Tubes / Valves | 30 | 10th September 2003 07:45 PM |
| Page generated in 0.07710 seconds (74.65% PHP - 25.35% MySQL) with 11 queries |
