Old 7th May 2011, 11:40 PM   #1
Bill poster's Avatar
Default compact OB sub - suitable 8-10" drivers?
I want to make a pair of small Infinite baffle subs to complement a full range design, therefore they don't need to be that powerful/loud, I just want to add clean bass extension at moderate listening levels.
I was thinking to mount each driver in a short fat tube/circular section about 25 cms long, firing sideways ( or firing downwards?).
What are suitable-for-IB, 8 or 10" woofers/subwoofers? I don't want to spend much. I live in the UK so I'm looking at brands such as Peerless, Monacor, Visaton, Seas etc.
Old 8th May 2011, 03:55 AM   #2
djn is offline djn  United States
djn's Avatar
Sounds like you are talking about OB (open baffle) vs IB (infinate baffle) The IB would be mounted in the floor, ceiling, or wall and totally blocked from your listening room on the back side.
If you want good OBs, look at Martin Kings paper on OB, "U" frames, or "H" frames. I had a pair of the "H" frames and they rock and DO NOT break the bank.
My "Art" website http://home.comcast.net/~djnagle/site/
Old 8th May 2011, 08:55 AM   #3
chris661's Avatar
Sounds like he means a sealed cabinet. There's some people calling sealed cabinets infinite baffle (some speaker manufacturers), when the two are only similar in that they stop the rear wave interfering with the output.
It is a pet niggle of mine, when people say IB meaning sealed.
For a sealed design, you're looking for a Qts of >0.5, but less than ~0.8. The former will give a smaller cabinet, but not as much bass extension. A higher Q needs a larger cabinet, but will give some more extension.
I'd consider being more flexible by adding the option of eq (in the form of a Linkwitz Transform): that way, you have control over how much extension (and excursion) you use, rather than it being governed by the driver and cabinet choice.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 8th May 2011, 12:27 PM   #4
Yes, sorry I've got that completely wrong, I mean open baffle - I guess I'm making a circular form of H frame.
So far I found these drivers might be suitable
Visaton GF200 8" (wired up in 4ohms) very good performance but expensive.
Dayton SD270-88 10" high sensitivity might be an advantage when matching
Monacor SPH-250KE 10" good performance but small xmax..
Monacor SPW -226/8 8" ok performance and V cheap! £19 in uk!
Old 8th May 2011, 12:30 PM   #5
djn's Avatar
I did not know that Chris. I does make sense though.
Old 8th May 2011, 12:32 PM   #6
djn's Avatar
You might want to read through this article. I had the Emenence Alpha 15a in the "H" frame and they just amazed me.....and the drivers and boxes cost just over $100 for all. I had the woofer amps already.
http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf
Old 8th May 2011, 12:51 PM   #7
The drivers have to be 8 or 10".Thanks for the tip, I starting reading through
quote from Martin King
"A search of the Internet will reveal that there are a number of commercially
available open baffle, hence forth abbreviated as OB, dipole speaker systems available
in the audio marketplace. Offerings such as Seigfried Linkwitz’s Orion(1), John Kreskovsky’s NAO(2), and Paul Hilgeman’s Ronin(3)can all be characterized as floor standing narrow baffle dipole speaker systems. Each features active crossovers and EQ filters requiring at least two amplifiers. These are all very sophisticated well engineered designs that allow the use of a narrow baffle while still producing satisfying bass output. The key to these designs is the use of active crossovers and EQ filters to produce sufficient low frequency output
Well this is interesting; I'm using 2 full range drivers which will be around 87 db each.
Yesterday I was looking at the cheap Monacor and Dayton which have high sensitivity 91/92 dB. I thought if I use a suitable low pass, I can 'manipulate' a flatter bass frequency response overall. Then late last night I read a review of the Jamo 909's and they have done exactly this.
Old 8th May 2011, 01:17 PM   #8
tinitus is offline tinitus  Europe
thread title corrected
moderation
Old 8th May 2011, 01:22 PM   #9
SPH-10M
new 10" Monacor
not really cheap, or impressive specs
Impedance (Z) 8Ω
Resonant frequency (fs) 29Hz
Max. frequency range f3-2,000Hz
Music power 200WMAX
Power rating (P) 120WRMS
SPL (1W/1m) 89dB
Suspension compl. (Cms) 0.41mm/N
Moving mass (Mms) 69g
Mech. Q factor (Qms) 2.62
Electr. Q factor (Qes) 0.60
Total Q factor (Qts) 0.49
Equivalent volume (Vas) 73.5 l
DC resistance (Re) 6.5Ω
Force factor (BxL) 11.5Tm
Voice coil induct. (Le) 1.1mH
Voice coil diameter Ø 50mm
Voice coil former aluminium
Linear excursion (XMAX) ± 6.25mm
Eff. cone area (Sd) 363cm2
Magnet weight 1.1kg
Weight 3.85kg
Old 8th May 2011, 01:55 PM   #10
Thanks Tinitus, sparing my blushes. That driver does look good on the graph.. will compare with the visaton.
THAM10 - a 10" compact TH proposal martinsson Subwoofers 29 25th May 2012 05:22 AM
This driver suitable for OB? Fast1one Subwoofers 9 25th April 2011 05:29 AM
10'' or 12'' OB coax drivers DaveCan Multi-Way 15 13th February 2011 11:19 AM
Most suitable amps for bi-amped OB spkrs ozziozzi Solid State 3 9th July 2006 12:18 PM
suitable ob drivers for low powered tubes mrthieme Full Range 3 5th July 2005 11:37 PM
Page generated in 0.12100 seconds (79.97% PHP - 20.03% MySQL) with 11 queries
