diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Fiddling with Hornresp - Peerless 831759 (http://www.diyaudio.com/forums/subwoofers/188283-fiddling-hornresp-peerless-831759-a.html)
DrDyna 2nd May 2011 05:16 PM
1 Attachment(s)
Just curious if anyone has messed with Hornresp, or made a horn subwoofer using a Peerless 831759?
I've got a few spares, but I don't want to go to a bunch of trouble if it's going to be terrible, however I am intrigued by building a set of horn subs just for fun to see how this driver sounds in one, even if it ends up being refrigerator sized.
Anyone ever try it, or can take a quick glance at the specs and tell me if I'm wasting my time?
Edit: attached specs.
DrDyna 2nd May 2011 11:09 PM
Anyone? I was thinking perhaps one in this design fasion:
Danley DTS-10 tapped horn subwoofer • DIY Audio Projects Forum
bjorno 3rd May 2011 02:34 AM
1 Attachment(s)
Peerless-831759 in a TH? :eek:: Don't spoil the good drivers...use in a TL or in a T-TQWT_ML-TL_BR, Closed box... or in a :
b:)
GM 3rd May 2011 05:00 AM
1 Attachment(s)
Originally Posted by DrDyna (http://www.diyaudio.com/forums/subwoofers/188283-fiddling-hornresp-peerless-831759-a-post2559067.html#post2559067)
No, specs indicate a keeper though, so bjorno's or do your own starting with soho's very flexible TL, TH designer.
BTW, loading specs into HR, then exporting them to a .txt file for posting allows others to load them or a whole design straight into HR [attached]. See pg. 7, 8 of the HELP file.
GM
DrDyna 3rd May 2011 11:27 AM
Originally Posted by bjorno (http://www.diyaudio.com/forums/subwoofers/188283-fiddling-hornresp-peerless-831759-a-post2559589.html#post2559589)
b:)
GM
Thank you guys very much, that TL does actually look easier to build, too!
Edit: Google as I might, I can't find anything about Soho's TL TH Designer. Is this software I can grab from somewhere?
DrDyna 3rd May 2011 02:24 PM
I like the way this alignment looks, do you think I could use Soho's TL-TH designer to model one like this for that driver? (I still can't find it though!)
Yves TL Subwoofer
GM 3rd May 2011 03:20 PM
Originally Posted by DrDyna (http://www.diyaudio.com/forums/subwoofers/188283-fiddling-hornresp-peerless-831759-a-post2559898.html#post2559898)
Thank you guys very much.........
You're welcome!
Interesting, I usually have good luck with Google, but not this time unless I search for 'eazy horn': eazy horn - Google Search
GM
GM 3rd May 2011 03:22 PM
Originally Posted by DrDyna (http://www.diyaudio.com/forums/subwoofers/188283-fiddling-hornresp-peerless-831759-a-post2560025.html#post2560025)
Yes.
GM
Jmmlc 3rd May 2011 03:40 PM
1 Attachment(s)
Hello,
Here is my proposal.
Best regards from Paris, France
Jean-Michel Le Cléac'h
DrDyna 3rd May 2011 03:58 PM
Thank you all again! I'm going to mess with this spreadsheet and see what I can come up with. I'll post an update before I put pencil to wood.
I'm pretty pumped to try it out.
Resources saved on this page: MySQL 18.75%
