Old 1st May 2011, 01:53 AM   #1
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Default looking for a 18" SW
budget for the driver is 400$, I am not very familiar with the SW business and kinda confused after the many projects I've seen. open to build almost everything from front loaded to taped horn to BR ... whatever. Just have no idea at all where I should start looking at.
humpfs ... thanks
Old 1st May 2011, 02:18 AM   #2
GM is offline GM  United States
GM's Avatar
Well, you have an Italian flag, but claim to be located in the Midwest, so for the latter, Google returned these: 18" subwoofer - Google Search
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st May 2011, 02:27 AM   #3
tarmac ripper
Gluca's Avatar
Well GM ... I am italian but I do live in the midwest, somehow it happened and I still can't figure out how things went and brought me here.
Heerr, actually I was looking mainly to a project people are happy with so I can get myself some wood and glue and start assembling it.
Old 1st May 2011, 04:39 AM   #4
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Home sub or Pro sub?
Dan
Old 1st May 2011, 11:46 AM   #5
DrDyna is offline DrDyna  United States
DrDyna's Avatar
This is more double your budget, but someone mentioned this to me the other day and I haven't been able to close the tab in my browser yet.
TC Sounds LMS Ultra 5400 18" DVC Subwoofer
I haven't built anything with an 18" in it however, so I can't recommend anything from personal experience, but parts express has several drivers that fit your budget and look to have respectable specifications on paper.
Old 1st May 2011, 12:04 PM   #6
GM's Avatar
Sorry, don't keep up with all the various builds, but this forum appears to build quite a few 18" subs, though probably well beyond your budget: DIY Speakers and Subs - AVS Forum
Again though, doing a Google search on each driver within your budget is probably your best bet as they aren't all that popular around here.
GM
Old 1st May 2011, 03:42 PM   #7
How about an Electro-voice? EVX180B I think you can get one for around $360-400.00
Old 2nd May 2011, 12:01 AM   #8
tarmac ripper
Gluca's Avatar
what about a iso-barik with a pair of dayton DCS450, it looks like I can get -3dB@20Hz into a 200lt cabinet
Old 2nd May 2011, 12:51 AM   #9
djk is offline djk
djk's Avatar
Why not dual 12s?
With dual drivers you can run PPSL and get about the same output that you would get from a medium priced 18.
22.9mm $179 12"
http://www.parts-express.com/pe/show...number=293-650
Candidates for the Darwin Award should not read this author.
Old 2nd May 2011, 01:10 AM   #10
GM's Avatar
You're welcome!
Yeah, I get ~224.34 L net/21.6 Hz Fb, but a very large, long ~238.33 cm^2 x ~55.82 cm vent to get a low vent mach and shrinking the cab will just make it smaller, longer, but at a glance, around 150 L net/21.6 Fb looks doable in a sim.
Maybe better overall building two ~150 L net cabs with some stuffing to 'tighten' them up and tuned to 17-18 Hz to get more room smoothing options and if you can get them into ~diagonal corners, all the better.
GM
Dayton 10" Titanic Mk III SW Kit lomax1 Subwoofers 0 30th December 2010 12:08 AM
Ciare sw 18 for tapped horn soundhead Subwoofers 0 27th December 2009 01:52 PM
Can I multiply an 18" folded horn cab by 0.8 for a 15"? Optical Subwoofers 7 31st October 2004 04:37 AM
North Leviathan 18-inch SW driver Val Multi-Way 4 26th August 2002 05:42 AM
Page generated in 0.09800 seconds (81.79% PHP - 18.21% MySQL) with 10 queries
