Old 25th April 2011, 12:21 AM   #1
nigelwright7557's Avatar
Default 34 inch subwoofer on youtube
YouTube - Largest Sub --- 34-INCH in Honda Z600 --- HUGE
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 25th April 2011, 12:30 AM   #2
Speakerholic
Cal Weldon's Avatar
You'd think they might have a better use for it, but what do I know.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 25th April 2011, 01:46 AM   #3
Pano is offline Pano  United States
Pano's Avatar
That's just goofy.
Old 25th April 2011, 02:13 AM   #4
Pointless.......for no other purpose than the "my **** is bigger than yours" contest.
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 25th April 2011, 02:18 AM   #5
johnr66 is offline johnr66  United States
Big sub in a too small enclosure. Typical.
Old 25th April 2011, 02:20 AM   #6
Speakerholic
Cal Weldon's Avatar
Perhaps it's intended to increase the neuron transfer rate. I guess they need a little more time, not working so far.
Old 25th April 2011, 02:51 AM   #7
18Hurts is offline 18Hurts  United States
Not bad
Thiele/Small parameters for AWT-34X:
Fs 13.6Hz
Qts 0.968
Qes 1
Qms 11.65
Vas 743 Liters (~26 cu ft)
Re 1.95 ohms
Le 1.15mH
Xmax +/- 30mm
Pmax 5000 watts
Assuming 1" plywood, the Zilla Audio BIB calculator gives me this
4 feet 4 inches wide
6 feet deep
20.5 feet tall...
At 211 pounds for the thing, I would use angle iron and steel plate to support it.
Efficiency is quoted at 89 dB
Then again, for 5K I could get 4 Danley DTS-10 DIY kits...
Sooooo....who is going to run 4 of them open baffle? Who will offer a flat pack BIB for that sub?
Old 25th April 2011, 02:58 AM   #8
katana2112's Avatar
Does it do anything other than.......rattle?
Aggressively Passive
Old 26th April 2011, 02:54 PM   #9
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Probably not, my guess is it's unusable above 40 cycles or so.
I'm still waiting for some twit to install one of these in a car.
Eminent Technology: home
Old 26th April 2011, 03:03 PM   #10
epa is offline epa  Netherlands
lol
.see that bafle moving.,
the speaker is worth more than the car.
Subwoofer down to 10Hz and only 1 inch deep! ashok Subwoofers 7 6th May 2009 04:36 AM
Update on Audiobahn 34 Inch Subwoofer Install tomtomjr Car Audio 9 29th November 2008 05:26 AM
FS 700va custom toroid transformer 4X 34-0-34 secondaries force of 1/2 Swap Meet 0 12th November 2008 05:39 PM
Audiobahn 34 Inch Subwoofer - Anyone ever build a box for one? tomtomjr Car Audio 26 24th April 2008 04:07 AM
6.5 inch Subwoofer lawbadman Subwoofers 29 13th July 2005 04:46 PM
Page generated in 0.10333 seconds (77.43% PHP - 22.57% MySQL) with 10 queries
