What ingredients to use in a music first subwoofer? (or two?)
Old 23rd April 2011, 05:41 PM   #1
jakja83 is offline jakja83  Norway
Default What ingredients to use in a music first subwoofer? (or two?)
I have a pair of standmounts (Active AVI ADM9Ts) in a 4x5 meter room and I need to augment them below 100 hz. I am considering building one (or two) small, sealed subs that can fill in the bass part. I need them to sound very clean and to measure flat.
I don't listen very loud so I don't need extreme SPL, SQ is the priority.
I need hints and tips on what type of driver and what type of amplifier to use with them. I was hoping to get decent extension a bit lower than 25 hz.
All help is greatly appreciated.
Old 24th April 2011, 12:54 AM   #2
GM is offline GM  United States
GM's Avatar
Hmm, flat to 25 Hz in a small sealed cab means either lots of room, boundary gain and/or lots of EQ and the power handling to use it, so high SQ may be hard to come by even at modest LF SPLs more felt than heard and until a driver can be found or some compromises made, there's no figuring out what amp to use, though for truly high SQ, it won't be a plate or prosound amp if not a recording studio grade $$$ unit.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th April 2011, 01:52 AM   #3
infinia is offline infinia  United States
infinia's Avatar
getting to 25 Hz is a problem (hardware driver) and is not necessary for a "music 1st" system. You should seriously re evaluate that spec esp for a sealed bass box. I think -6 dB at mid to low 30's Hz is more than reasonable for music. Maybe you could consider switching in another box (vented) and amp for HT LF effects when called for?
Old 24th April 2011, 03:18 PM   #4
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Default Corners.
I've got a couple of subs that I use you might be interested in. The drivers are older Peerless 10"s that they don't make anymore, but I think you could probably use something like this:
https://www.madisound.com/store/prod...roducts_id=686
The cabinet is a really interesting ported design, like wedges that sit in the corners, which I and the designer refer to as "corner loaded". They don't occupy a whole lot of room, are fairly efficient and get down pretty low. I'd give you dimensions, but you'd probably have to recalc the internal volume and port for the new woofer anyway.
Edit: ignore the black box they are sitting on, those are my bipolars.
Old 24th April 2011, 03:47 PM   #5
Brett is offline Brett
Brett's Avatar
Not sure what you can get in the EU or if shipping is viable, but my generic choice for a modest size sub would be a Shive V2.
GM
Plate amp, no, but there is no reason at all not to use a pro amp for a sub with an external xover/EQ, unless of course you want to spend lots more than you need to for no difference.
Old 24th April 2011, 03:51 PM   #6
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
This sub I designed might fit your requirements, though it's not the most straightforward build:
http://www.diyaudio.com/forums/subwo...i-vi-d10g.html
It uses ordinary woofers, which do have great low end response, but they are used in this design really because I have them and wanted to see what could be done with them (and a 160W amplifier).
It is a music sub design which should have response to under 30Hz, low distortion, smooth, fast sound. Ideally sits in a corner. SPL is not too limited with the dual 10" drivers.
Old 24th April 2011, 03:51 PM   #7
studiotech is offline studiotech  United States
Just a build a pair of these. You cannot do better for anywhere near the money.
Rythmik Audio 12" servo subwoofer " DS1200 Custom Installation subwoofer
See my 15" version here:
Sonotube style builds no longer en vogue... - AVS Forum
Greg
Old 24th April 2011, 07:16 PM   #8
5th element is offline 5th element  United Kingdom
5th element's Avatar
There is always the good ole' XLS from Peerless.
These work well in very small sealed enclosures. Attached is the driver in a 20 litre box with a LT, 100hz low pass and a subsonic filter. As can be seen the driver hits Xmax with only a small amount of amplifier power re 20hz. This results in a relatively low free field SPL @ 20hz, but if combined with room gain and boundary reinforcement (putting the sub in a corner), you can get about 95-98dB out of one. A 200 watt @ 4 ohm amplifier should be plenty too.
Build two of these and you'd be pretty well set.
Edit - the power required would be a little confusing, @ 20hz you need 70 watts into an 8 ohm load to hit xmax.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 24th April 2011, 09:37 PM   #9
I have been "tipsed" to prioritize the area above 30 hz and insted focus on making a sub that can produce a pretty flat response up to 100+ hz as my standmounts need some help further up.
I can get my hands on Peerless drivers fairly cheap. Both XLS and XXLS 10s and 12s, but perhaps they aren't the best drivers for upper bass performance?
I can also get drivers from Seas for a fair price e.g.
Seas driver info
What kind of amplifier do you suggest then? I could build 2 passive units and get a outboard amp, noe sweat - just need some concrete products to look up...
Old 24th April 2011, 10:25 PM   #10
infinia's Avatar
I see that there is an AVI 10' sub made for this system. Is there a problem going this route. Did you plan on using the digital inputs much?
Probably a system with two 12" peerless sealed subs could be very good choice with a separate amp, either a pro-sound or mid-fi amp >200 watts, not sure what your choices are over there. Before you select a sub woofer driver and alignment, The big choices you need to focus on, what is the best way to achieve the 'crossover' to the subs and integrate them the levels into your room space. I would find out what the built-in sub output filters do and how steep they are. Do they depend on using the natural LF response of the stand mounted mid-bass?? The most flexible in terms of integration and fine tuning things ( X-over frequencies ) and gains, would be using external crossovers, but then you would lose the digital inputs.
What ingredients to use in a music first subwoofer? (or two?)Hide this!Advertise here!
Household ingredients pcb etching!!! Rodeodave Construction Tips 2 7th May 2011 09:01 PM
CSS Trio8 music subwoofer implementation? Brisso57 Subwoofers 21 26th November 2009 12:07 AM
great music subwoofer on a budget ifonly Subwoofers 27 27th April 2006 09:54 PM
when does using a subwoofer make sense in a music-only setup? keyser Subwoofers 48 22nd November 2004 08:57 PM
JE Labs 300b round 5. MUSIC!! MUSIC!! TubeHound Tubes / Valves 14 11th January 2003 01:02 AM
