Air leak in ss15 TH severely affect output?
Old 26th April 2011, 04:56 AM   #21
Djim is offline Djim  Netherlands
Originally Posted by m R g S r View Post
nooo its not like i really need that much more low end, its fine really i guess im just used to hearing the effect of cabin gain in my car or hearing the songs played on multi hundred thousand dollar stereos in clubs lol
Don't worry, breaking out an SS15 as advice was also meant with a little sarcasm. Btw you can easily use as much EQ you like with your SS15 to push some 40Hz tones cause that 30Hz filter of yours is good enough to hold 350watts under control (even if the driver didn't suffer from pwr/dyn compr.)
Old 26th April 2011, 05:23 AM   #22
m R g S r is offline m R g S r  United States
okay thanks a bunch man i appreciate the help!
Old 8th March 2015, 05:14 PM   #23
rslick66 is offline rslick66  United States
Default part express speaker caulk
Parts Express sells a speaker caulk that is kind of like window glazing, in little strips of rope. If your gaps aren't too big, that stuff will fill your voids, and it seals around handles and dish plates. Good Luck.
Old 8th March 2015, 08:10 PM   #24
zettairyouiki is offline zettairyouiki  United States
The last post in this thread is nearly 4 years ago. I imagine he's either fixed the issue or moved on at this point.
Air leak in ss15 TH severely affect output?Hide this!Advertise here!
Leak Delta 70 with MOSFET output stage ashok Solid State 9 6th January 2018 04:57 PM
Source for output air cor output inductor?? sam9 Solid State 12 2nd July 2015 07:44 AM
Leak Stereo 70 output caps suggestion Leolabs Solid State 1 21st January 2010 01:48 PM
Output Transformer Air Gap sousmielie Tubes / Valves 3 25th July 2008 11:28 AM
parts express 500 watt air leak ejn327 Subwoofers 5 25th October 2005 03:54 PM
