Old 20th April 2011, 04:33 PM   #1
hawkson is offline hawkson  United States
Default Please analyze these A&D Subwoofer Drivers
http://www.ad-audio.com/pdf/D18L1012_D18G812.pdf
http://www.ad-audio.com/pdf/s18l1010_s18g810.pdf
These are from A&D Audio. I would like to use them for HT.
Can they go loud and low? I would like to use them in a dual sealed box.
How would these compare to other popular 18" drivers?
Old 20th April 2011, 05:19 PM   #2
Have you heard of WinISD? you can use it to design a box suitable for the speaker, they have an xmax of 6-7mm which is not a lot, but the large surface area would make up for it to some extent, also the Fs is in the 35-40Hz area, that is a bit high for home theatre.
What are you size restrictions for the box? It might work in a large Horn sub!
Old 20th April 2011, 06:29 PM   #3
18Hurts is offline 18Hurts  United States
Those are pro audio woofers
The resonant frequency is rather high so a sealed box is a no go. Ported or passive radiator can be tuned to 27Hz if you are careful and don't mind a large box.
Horn loading two of them would be a giant box! Do you own the woofers or are thinking about using them? First figure out how low you need (15 to 20 Hz for HT sub) how loud you want it to be then how big you can go. Those eighteens would be great for music in a sealed box but you'll lose the bass at under 40 Hz unless you EQ heavily.
Old 20th April 2011, 10:22 PM   #4
Ideally they are for HT and I am considering buying them because they are made near me(China).
They aren't rated for HT use, are they?....
I have heard downloaded WinISD. Still choosing drivers before modelling a box.
Old 21st April 2011, 09:20 AM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI: HT use for one or two A&D-D18G812:
b
Old 21st April 2011, 12:58 PM   #6
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Those will probably be terribly boomy without a massive vented cabinet or a horn which could easily consume half of your living room if built properly large to get those to play well.
Those drivers you linked are most likely made for applications like this:
Concert sound systems
and not for home theater or music use.
I think Hi-Vi (also a Chinese company iirc) makes a couple of decent drivers that would probably perform better as home theater subs in small boxes with plate amps and their gobs of eq, like this kiddo here.
https://www.madisound.com/store/prod...oducts_id=1485
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 26 3rd March 2012 01:37 PM
FS: 1 pair of B&C 21SW152-8 21" Subwoofer Drivers. opc Swap Meet 14 6th February 2012 04:49 PM
Suitable Drivers For My Subwoofer Amp rikhav Multi-Way 2 10th January 2007 11:41 AM
Subwoofer using two old Philips 12" drivers? Risk Subwoofers 0 16th August 2004 08:35 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Page generated in 0.10031 seconds (60.75% PHP - 39.25% MySQL) with 11 queries
