Old 20th April 2011, 12:09 AM   #1
Default what to do with 12 mcm 8" speakers
I have twelve mcm 55-2421 8" driver what to do with them. Confuse here. looking for 30 to 200hz.
Old 20th April 2011, 12:21 AM   #2
jbell is offline jbell  United States
which mcm's ???
hopefully 55-2421's.
Old 20th April 2011, 12:23 AM   #3
yes sir
Old 20th April 2011, 12:23 AM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
Originally Posted by soundhead View Post
I have twelve mcm 8" driver what to do with them. Confuse here. looking for 30 to 200hz.
That's almost subwoofer territory, sounds like you've got a set of good woofers.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th April 2011, 01:21 AM   #5
Put it all into a big ol ported box!
Old 20th April 2011, 01:40 AM   #6
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by jbell View Post
which mcm's ???
My thought's exactly, every other MCM driver I've tried was total rubbish in the TSP department.
jbell is modest, he has posted a couple nice horn variations for this driver.
Dan
Old 20th April 2011, 01:41 AM   #7
18Hurts is offline 18Hurts  United States
JBell built horn loaded subwoofers out of a pair of those 8's. It rolled of at 40Hz but might work for you with a redesign.
Dual MCM FLH
Do you want 12 subs, 6 subs or one giant sub? How large can you go?
Old 20th April 2011, 01:52 AM   #8
ByronInLawrence's Avatar
Location: Lawrence, a nice little college town in Kansas
Hi Soundhead,
There's an awful lot one could do with 12 woofers like that. Here is what I would do if I had 12 of these woofers:
Option 1, easiest:
  1. I took the liberty of finding and attaching the data sheet on your woofers. Save it to your computer.
  2. Download one of the many free box design programs available. Here are two really simple ones that you don't even need to download: http://www.mh-audio.nl/ReflexBoxCalculator.asp and http://www.mh-audio.nl/CBC.asp
  3. Play around with alignments, sealed vs. vented (I think your driver is designed for vented), box sizes, etc . . .
  4. Choose your design and build an awesome subwoofer!
Option 2, harder, but more fun, with better chance of good results:
  1. Save attached data sheet to your computer.
  2. Go here: SPL Tools and download SPL tracer.
  3. Use SPL tracer to make at least a *.zma (impedance graph) file. You could also make an *.frd (frequency response) file.
  4. Download free software which will allow you to use your *.zma and *.frd files to model a box. I use Speaker Workshop (SW), which can be found here Speaker Workshop I don't like SW, but it's the best thing I've found for free.
  5. With the help of the many online tutorials, learn to use SW just enough to design a subwoofer.
  6. Design, then build, the ultimate subwoofer!
Option 3, probably not worth the effort unless you're really hard core.
  1. Don't bother with the manufacturer's data sheet, because it may not be accurate.
  2. Download SW, and learn how to use it to measure impedance.
  3. Build yourself a Wallin Jig. Instructions are here Eric Wallin's Internet Homepage. Don't worry, it's not expensive, but it is time consuming.
  4. Use the Wallin jig, along with an external amplifier, and Speaker Workshop to generate *.zma files and calculate T/S parameters. If you want to be obsessive, make a separate file for every driver.
  5. Don't bother with *.frd files - too difficult and expensive, and not necessary for a subwoofer.
  6. Use said *.zma files to design a box or boxes for your speakers!
That's just what I would do. I'm sure you'll get lots of suggestions.
-Byron
Old 20th April 2011, 01:53 AM   #9
A tapped horn design four mcm per box will do.
box size 20x32x45
Old 20th April 2011, 01:56 AM   #10
one more thing . . .
If you don't want to use all 12, I'm sure you could find people at the swap meet forum who would be willing to buy a few from you.
Coral fullrange speakers 12" cypher Full Range 13 1st April 2009 05:58 PM
MCM 12" pro woofer? AdamThorne Multi-Way 2 14th September 2007 01:53 PM
Cheap 12" sub - MCM 55-1255 bigwill Subwoofers 6 7th March 2005 09:49 PM
Page generated in 0.12714 seconds (66.10% PHP - 33.90% MySQL) with 11 queries
