Hi! today i just finished my model of my first bass reflex design (first speaker ever) with a Fane Colossus 18XB. I did it with agglomerate becaue i knew i was going to make some mystake (like i did) and to check stability and know where to put braces, if necessary. Now i know they are not really necessary.
And Tomorrow i'll build the final cab with plywood 18mm. Here goes my first question: you think its possible that i wont need braces?? I standed up on my box, and jumped on it, and it only broke a little bit....But maximum there will be 4 more boxes on top....(30kg * 4 = 120kg)..... Any advice? =========(sorry for this offtopic question)=================== Well the goal of the topic, is: Now i have a port length of .240 but i'll make it a little bit longer, or make tomorrow some pieces of different sizes. To compare the difference of sound between different length. My question is, wich easy and simple method, without any mesurement equipment, can i use to sintonize and trim the port length??? I tryied with a AC voltimeter, but it's not precision enough, because it was really cheap one(30 euros....) Any help please?? THX FOR YOUR HELP
#2 |
The best way is to get a modeling software, like WinISD (free) and use it to help with the design of the cab. It helps take the guesswork out of the build so less need to tune.
I would definitely brace a cab of that size. It is not only the strength of the cab the bracing improves, it also helps with the sound reproduction by keeping the sides from vibrating and coloring the sound. |
#3 | ||
Just put a few hundred Watts through the 18XB and feel the cabinet walls move! Quote:
By the way, you're going to use t-nuts in the end-product? Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#4 |
Braces are not put in to keep the box from getting crushed, they keep the walls stiff.
Reusing Old Sub Boxes? Post # 5 tells how to check for port tuning frequency. |
#5 |
"wich easy and simple method, without any mesurement equipment, can i use to sintonize and trim the port length??? I tryied with a AC voltimeter, but it's not precision enough, because it was really cheap one(30 euros....)
Any help please??" Winisd freqvency generator will help you out on thisone. The chep multimeter is more than suffiecent to mesure Your tuning freqvency, and help you with the tuning. If You plot the impedance curve of the driver, now that it is in the box, You will see a peak in the impedance curve, that is where the port has tuned the cabinet. Voltage divided by current is impedance. This is a very easy methood, and it is accurate enough. |
#6 |
#7 |
Right, you definitely want bracing. It's not so that you can park a car on the cabinet, it's so that the vibrations produced by the speaker affect the cabinet less. For a cabinet of that size, you should probably have 3 or 4 internal braces.
#8 |
Wow that's very similar to mine, including the recessed shelf port brace.
JEREMY M_________________________________ I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ? |
#9 |
#10 |
I em allways surprised how can i mess it up allways
this one is easier done than told it seems. Apologies if i mislead anyone. |
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| port length | busterno1 | Multi-Way | 5 | 27th October 2003 08:05 PM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.17093 seconds (56.20% PHP - 43.80% MySQL) with 11 queries |
