Old 5th April 2011, 07:36 PM   #1
DIYNick is offline DIYNick  United Kingdom
Default Passive sub, stumped already
Hello experts. I bought a Jamo passive sub very cheap to mess around with and bolster the sound from my full range driver set up
I'm powering it from a spare autocostruire 2020 t amp board, but I'm confused. There is a vibration inside which I thought could be loose driver bolts. (which it wasn't although I did get a few turns on the bolts). On opening the box the two drivers for each channel face each other on the same baffle. One with it's rear to a sealed box and the other with it's rear to a ported box. Surely this cancels most of the sound out?
1) how does this work
2) Output is low as well, do I need a more powerful amp?
Thanks in advance, nick
Old 5th April 2011, 08:29 PM   #2
6L6 is offline 6L6  United States
6L6's Avatar
The drivers are in an "Isobarik" arrangement, and as one of the drivers is connected in reverse, the cones move with each other.
The 2nd driver is acting like a much bigger box, which keeps the actual box small, with high WAF.
Old 5th April 2011, 08:46 PM   #3
6L6, ok thanks for explaination, now I see. I need to check the wiring as it was loose and disconected when I opened it up. Any idea how efficient such an arrangement is? Does it need a big amp to get it working correctly?
Nick
Old 5th April 2011, 09:07 PM   #4
picowallspeaker's Avatar
Nick ,have you seen the statistical distribution of energy in the audio spectrum ?
Most goes to bass ...depending on which kind of music ,of course .
so the amplifier is asked to deliver current at the very low frequencies.Power in / power out equals efficiency ? If you just put a steep highpass filter before the sub .. Power ( sound SPL ) delivered by a pair of woofers in P-P ,but this is applyied to any kind of driver ,it depends of how they behave in their useful bandwidth ,so if you cross them right you reach optimum efficiency
Old 5th April 2011, 09:36 PM   #5
Picowallspeaker, ok I understand the principle of what you're saying, my ability to apply it may not match this! On removing the bottom of the unit there is on each channel input an inductor and a capacitor. Would this be the low pass filter?
I have now reversed one of the drivers so + and - are the opposite to the other driver. (although this goes against the colour coding) output has increased now.
I still have a vibration/rattle at certain frequencies, which is annoying. Can't see anything obvious yet that maybe causing it.
Old 5th April 2011, 11:24 PM   #6
revboden's Avatar
Photos would help, what kind of drivers are they? What brand size etc?
Old 6th April 2011, 12:59 AM   #7
Check to see if the inductors in the x-over board have come loose.
That sounds like a "clamshell" isobaric 4th order bandpass system. See the following link for an example of such a system: ElUglito
Old 6th April 2011, 07:10 PM   #8
Photo attached of current/original condition with bottom access open.
Divers are approx 8" overall dimension, so about 7" across the cone. (can't see a brand, it has 'Jamo' stickers on).
Wiring could be ratling as is doesn't seem to do it now I have opened the box
Comments welcome.
Old 6th April 2011, 07:27 PM   #9
Curious design choice. I'd be concerned about leakage between the two volumes because of where and how they implemented that separation panel.
Old 6th April 2011, 07:45 PM   #10
Brian,
Mmmmmmm....yes, I did think about that, i'm a bit reluctant to perminantly seal it, until at least i'm happy with the sound. I have rapped foam around the inner cables, secured with zip ties for now, this has improved matters, just a slight rattle at higher volumes/certain frequency.
Do you think the inductor/capacitor arrangement is a low pass filter then?
SMPS repair has me stumped PM650 Power Supplies 3 19th January 2009 09:56 PM
Stumped---Floppy Drive BluesMagoos Analog Line Level 4 5th March 2008 12:58 AM
audiobahn a2300hct has me stumped ppia600 Car Audio 25 9th August 2007 02:18 PM
Stumped on 2nd Re-Cap and need help 65blkbkgt Car Audio 14 16th July 2007 02:59 PM
Computer problem has us stumped RADIOLEE Everything Else 7 9th March 2004 07:08 AM
Page generated in 0.20614 seconds (42.25% PHP - 57.75% MySQL) with 10 queries
