Old 5th April 2011, 03:58 PM   #1
BrianVG is offline BrianVG  Belgium
Default Visaton WHC 30 X
Hi all,
A while ago I bought this Visaton driver.
http://www.produktinfo.conrad.com/da...e_en_fr_nl.pdf
I used Boxsim to simulate an enclosure.
Closed, 60l.
What do you think?
I want to use it as a subwoofer for watching movies.
The amp I'm using is a DIY MOSFET IRFP9240/240, about 50W.
Maybe an iNuke NU1000 from Behringer later on.
I want to use a low-pass filter (active) and cut-off at 150Hz.
Do you think this is going to beat a Yamaha YST-012
Anything that I could improve?
FET fanatic
Old 6th April 2011, 12:08 AM   #2
revboden's Avatar
The sub you designed would be good for music. That driver wants to be in a larger box though, (driver Vas 146L) I'd use 100L minimum. Without knowing Xmax it's hard to model a ported box for it.
The yamaha is what I call a burp cannon. It will make a good bit of noise between 40 and 80hz but the transient response is crap. Not good for music at all, but if all you want is rumble for movies it does make noise...
Old 6th April 2011, 09:54 AM   #3
Using a bassrelfex won't give good results. Qts is above 0,6.
See below for the T/S parameters from Boxsim.
Xmax is 9mm, so 18mm total.
60l looks like a good compromise to me. I've aslo simulated a 100l enclosure, no big difference.
100l
FET fanatic
Old 10th April 2011, 01:59 PM   #4
It's going to be a bandpass!
FET fanatic
Old 10th April 2011, 07:20 PM   #5
The bandpass appears to have far less output than the 60L sealed box.
It only has 2 dB more output at 40 Hz, then drops at a much steeper rate.
Why would you want to throw away more than 5 dB of overall sensitivity and get a 5 dB peak at 100 Hz?
85 dB at one watt works out to about 105 dB at 50 watts.
At 30 Hz, the output level is only 91 dB at 50 watts.
It takes almost 20 dB more level at 30 Hz for an average person to perceive the level to be the same as at 100 Hz.
Movies often have considerable content below 30 Hz.
The bandpass box will unload rapidly below Fb, the speaker probably will exceed Xmax even with 50 watts unless you HP at about 35 Hz, which will then loose any "feel" of T-Rex thumps and battleships being crushed, and the low B on a bass guitar.
Art Welter
Old 11th April 2011, 12:03 PM   #6
Some people already adviced me to use a transmission line instead of a bandpass
Transmission line would be able to deliver that 30Hz, but I have no idea what SPL it has.
FET fanatic
Old 16th April 2011, 02:53 PM   #7
Default Someone check this
Ok, I've calculated the port with WinISD, enclosure is 60l and needs to be tuned at 55Hz, it's 9,5cm diameter and only 5cm long. Is this correct? Looks short
FET fanatic
Wanted: 30-0-30 500VA transformer x 2 (UK/EU) firestorm Swap Meet 0 12th January 2011 01:30 PM
Visaton FRS8M 30 Watt 88 dB any good? owenhamburg Full Range 20 14th May 2010 06:54 PM
Premier Speaker Stands ... by Paradigm -- model: S-30 (30"tall) Livin Swap Meet 10 3rd February 2009 02:08 PM
Visaton Fiesta-30, Is it worth? bezobraznia Multi-Way 3 8th July 2004 12:29 PM
Page generated in 0.13101 seconds (65.21% PHP - 34.79% MySQL) with 11 queries
