Old 4th April 2011, 12:07 AM   #1
endrek is offline endrek  Spain
Default How can i mesure how Fs changes with 2 drivers(same)??
Hi!
this thread is quick question. How can i verify, how much will the Fs from a driver change if i use 2 drivers(same) in standard configuration??
How can i mesure it? Doing the same as mesuring T/S parameters but with the two drivers in paralel? like this:
Set up diagram Click the image to open in full size.
But instead of one, the two drivers?
Thanks in advance
Old 4th April 2011, 12:17 AM   #2
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Just wire the drivers in series or parallel.
Mounting them to a baffle at the same distanc as the final design would also be good.
Purely academic exercise IMO
Dan
Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! Ulisez Power Supplies 13 23rd November 2010 06:42 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 04:34 PM
Mesure box losses REALFLEO Multi-Way 2 7th February 2007 01:06 AM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Page generated in 0.08268 seconds (63.88% PHP - 36.12% MySQL) with 10 queries
