Old 3rd April 2011, 11:26 PM   #1
djn is offline djn  United States
djn's Avatar
Default Do 2 woofers need a bigger box than 1?
Hi All, I just got 4 CV S-10.4 sub drivers and want to make some small cubes for a distributed sub set up. When I look at box size, how do I look at 2 drivers in di or bi pole? Does the box have to be bigger than if I was only using 1 driver?
Old 3rd April 2011, 11:44 PM   #2
endrek is offline endrek  Spain
I'm i've looking at the same question, but i'm a newbie so , my answer don't take it seriuosly , just to "try and guide you", but i'll try and help
I've opened a post with my design, with 2 driver setup, and what a i did is do the calculations as they where one but changing the T/S parameters (*2Vas, *2Sd, Fs=>??? still don't know how to predict it or mesure how it will vary if 2 driver standard configuration are setup... But think they said Fs goes down 1 or 2 Hz...dunnno)
Well, i did an excel, and did the calculations for 1 driver Vb(L) =198,82L, and then for 2 drivers Vb(L)= 442,14539 both with the same alignment C4 and a Bass reflex box.
Dunno...if it has answered the question...? But i think the box has to be bigger, or atleast the calculations say so
for sure a lot of knowledge people here, will correct me and give better answer
Old 3rd April 2011, 11:56 PM   #3
Yes
Old 4th April 2011, 12:38 AM   #4
djn's Avatar
I don't have the T/S for these drivers and as far as I can tell CV never published them. I have a friend with Woofer Tester. I'll have to get over to his place and test them, then I can calc the box size. I was kind of hoping the answer would be "no" the box does not have to be bigger. Oh well.
Old 4th April 2011, 01:06 AM   #5
I if you plan on putting two identical woofers in one box you must double the volume of the box as if you were using a single woofer to get the same performance as one woofer.
Use a program such as "winlsd" (it is free) to model your box once you get your t/s parameters as it will be much easier and less of a headache than doing all the math by hand. jer
Old 4th April 2011, 01:51 AM   #6
djn's Avatar
Thanks Jer. I'll do that.
Old 4th April 2011, 02:35 AM   #7
Default Two Drivers, same box
[QUOTE=endrek;2526666]I'm i've looking at the same question, ....what a i did is do the calculations as they where one but changing the T/S parameters (*2Vas, *2Sd, Fs=>??? ... But think they said Fs goes down 1 or 2 Hz...dunnno)....
Dunno...if it has answered the question...? But i think the box has to be bigger, or atleast the calculations say so... End Quote]
Hi there: For two identical drivers: Vb, the box size will be twice the volume for one. and ...Vas, (a T/S parameter) will be twice the value of one. and....The impedance (ohms) when connected in series will be twice th value of one and when connected in parallel will be one half the value of one. ...Fs, the driver free air resonance for one will not change when using two. ... Cone movement will be one half when two drivers are used. ...regards, Michael
Old 5th April 2011, 06:10 AM   #8
You can calculte pretty ease way the T/S parameters. Thats what i'm going to do when my drivers arrive home
T-S Parameter Calculator
13 inch Seas woofers H175 33F-ZBX/DD woofers brand new in the box josemedeiros Swap Meet 0 11th January 2011 01:43 PM
Multiple woofers in a sealed box. RussellW Subwoofers 3 11th September 2010 07:36 PM
4x dynaudio 30w100 woofers, seperate boxes or all in one box? discl Multi-Way 0 5th February 2008 03:34 AM
Novice Question: Stereo Woofers in One Box joshkrahn Multi-Way 7 20th December 2007 01:31 PM
FS: pair of new Lambda TD-15S sealed box woofers taloyd Swap Meet 2 5th June 2006 02:45 AM
Page generated in 0.16803 seconds (61.39% PHP - 38.61% MySQL) with 10 queries
