This is the box that I currently have in my 1999 Ford Taurus with a 220 watt pioneer kicking it. The box does have a divider board between the 2 drivers the same thickness as the rest of the box. This is the proper drivers in it also, got the model number off the magnets.
File: My box in the car now.bb6 ----------------------------------------- Driver Properties Name: 40-1017 (PRO-CSW800) Type: Standard one-way driver Company: Radio Shack Comment: Pro-Series No. of Drivers = 2 Mounting = Standard Wiring = Separate Fs = 45.1 Hz Qms = 12.07 Vas = 21.8 liters Cms = 0.326 mm/N Mms = 38.2 g Rms = 0.897 kg/s Xmax = 5.112 mm Xmech = 7.668 mm P-Dia = 166.2 mm Sd = 218 sq.cm P-Vd = 0.111 liters Qes = 0.6 Re = 2.89 ohms Le = 1.1 mH Z = 4 ohms BL = 7.21 Tm Pe = 100 watts Qts = 0.57 no = 0.321 % 1-W SPL = 88.4 dB 2.83-V SPL = 91.64 dB ----------------------------------------- Box Properties Name: Type: Closed Box Shape: Prism, slanted front Vb = 0.808 cu.ft Qtc = 0.844 QL = 6.879 F3 = 67.65 Hz Fill = none This is my box after running thru Bassbox Pro to improve it. What do you guys/gals think? Did I do it right or do I need to do some more number crunching. You will notice that I modeled it as a bandpass enclosure and added 2 vents at 2" in diameter and 4" long. I tried adding filling to both but not like the plots. File: My box in the car now but improved-c.bb6 ----------------------------------------- Driver Properties Name: 40-1017 (PRO-CSW800) Type: Standard one-way driver Company: Radio Shack Comment: Pro-Series No. of Drivers = 2 Mounting = Standard Wiring = Series Fs = 45.1 Hz Qms = 12.07 Vas = 21.8 liters Cms = 0.326 mm/N Mms = 38.2 g Rms = 0.897 kg/s Xmax = 5.112 mm Xmech = 7.668 mm P-Dia = 166.2 mm Sd = 218 sq.cm P-Vd = 0.111 liters Qes = 0.6 Re = 2.89 ohms Le = 1.1 mH Z = 4 ohms BL = 7.21 Tm Pe = 100 watts Qts = 0.57 no = 0.321 % 1-W SPL = 88.4 dB 2.83-V SPL = 91.64 dB ----------------------------------------- Box Properties Name: Type: Bandpass Single-Tuned Box Shape: Prism, Bandpass with two chambers Chamber 1 - lower-freq. Vb = 1.323 cu.ft Fb = 63.3 Hz QL = 6.889 F3 = 42.15 Hz Fill = normal Chamber 2 - upper-freq. Vb = 0.846 cu.ft Fb = 69.67 Hz QL = 7 F3 = 117.1 Hz Fill = none No. of Vents = 2 Vent shape = round Vent ends = one flush Dv = 2.5 in Lv = 4 in Let me know what you all think of the improved version. Also let me know of any suggestions you might have to better improve it using the current drivers and amp and car. Just playing around with my old box until I get started on my new single 10" driver vented cube box. |
| Compare of opamp’s | bdef | Analog Line Level | 6 | 9th November 2006 06:22 PM |
| Where should be fb compare to fs | ostie01 | Subwoofers | 8 | 9th May 2006 10:56 AM |
| How do my speakers compare? | ThSpeakerDude88 | Multi-Way | 25 | 6th August 2005 05:40 PM |
| New 6s45p compare to NOS? | walkwalk | Tubes / Valves | 0 | 11th July 2005 01:48 PM |
| How do they compare???? | DJNUBZ | Solid State | 1 | 26th April 2005 12:12 AM |
| Page generated in 0.08642 seconds (62.11% PHP - 37.89% MySQL) with 10 queries |
