3015lf TH @ 35-40hz but only 20" deep help - Page 8 - diyAudio
Old 22nd January 2013, 06:17 PM   #71
maxo is offline maxo  United States
Ok, i almost ready to get the drivers
So they need to be the Eminence Kappa 3015LF
the neodymium or the heavy ones but just the kappa's
or any other than the SS15 from Jbell take right ?
Old 30th January 2013, 05:12 PM   #72
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi maxo,
Ref. Your P: Here are a couple of drivers I tested in the original box:
b
Old 30th January 2013, 05:48 PM   #73
Hey bjorno
so that means.... err...
can you talk some English please...
Old 30th January 2013, 06:34 PM   #74
Hey bjorno
So that means you have to...DIY...= compare the numbers to epa:s design or my initial design...or to don s. I have no idea what you don't understand...
b
Old 30th January 2013, 07:41 PM   #75
Ic.. well, i think i cant get 3 or 4 drivers of different flavors
so i will stick with the suggested one
Old 7th February 2013, 12:00 AM   #76
Originally Posted by epa View Post
this you can give to the carpenter/someone with a sawtable.
i numbered the cuts ,so every thing becomes the right width.
Epa this is great but i notice that there are no Y axis dimensions for cuts 1,2,3,8,9
Old 7th February 2013, 12:54 AM   #77
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
You OK? All dimensions needed have been provided.
Dan
Old 7th February 2013, 01:03 AM   #78
dan,
for example cut 1 u got the x dimmension but what is the distance from the top edge od the ply to the horizontal line where u will get a sub panel and a leftover piece for a brace
Old 7th February 2013, 01:06 AM   #79
what the effff.... i can see now on the cell....but not on the pc... never mind i need to see what the efff with this pc
Old 7th February 2013, 01:06 AM   #80
NEO Dan's Avatar
It's whatever the sheet of wood width is -1066mm[41 15/16"].
The brace is whatever is left over, part 1's dimmensions are what's important.
The only thing you don't have here is the driver cutout...
Dan
FS: BG Neo3 PDR - Special OEM "Deep-Back" Version mac Swap Meet 4 16th December 2015 05:17 AM
simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak? mige0 Software Tools 19 29th December 2010 04:00 AM
3015lf? mike james 533 Subwoofers 29 18th April 2010 01:00 AM
Driver in deep baffle"tunnel" marcus1 Multi-Way 4 6th December 2009 07:18 PM
Copyright 1999-2017 diyAudio
