#61 |
Thanks Epa
you daaaa man !! |
#62 |
Hey one thing
on cut 7th what are the measurments for the diagonal cut for the brace also on cut 5th the baffle, what are the measurements for the hole center |
#63 |
11" on the short side 45 degr angle.
place the woofer as close as posible to the end of the baffle. make sure it stil fits properly. aprox 8"center
one good thing about music ,when it hit you feel no pain. so hit me with music.
#64 |
#65 |
FYI: b
#66 |
Bjorno
Love it!!! can you post individual pics full res ... Please Please !!!!![]() hey i see 2 SPL graphs, one is HIFI the other is PA how do you get the diferent responses, does the plans need to be changed ? how do you get one or the other i want it for PA Last edited by maxo; 9th January 2013 at 11:09 PM. |
#67 | |
Why needing individual pictures, why not just hit the zoom/expand cross at the lower left corner of the thumb nail?* Most of the picture concern the PA version that do not need to be changed, (Epa's cut list is IMO ok, Thanks Epa!) and I only added the Hi-Fi T-TQWT version(enclosed within a wide border line of light Grey color) for comparison, that besides the upper FR boundary differences uses a larger volume = +34L, has a negative tapering that should be properly damped if to achieve Hi-Fi SQ. *The part of the picture that has the visible lowest resolution is the plot at the lower right corner is depicting: When trading SPL from the PA variant to BW similar to the T-TQWT's FR: An +(7-8 dB) shelving function inserted at ~33 Hz(An LT circuit can be used to manipulate the PA variant to achieve a very similar 'low end' like the showed variant 'Hi-Fi' is inherited from another box dimensioning.). Submitting a magnified picture: b
#68 |
Opsss i missed the actual size function
Now i can see !!! |
#69 |
Hey DON , EPA
please tell more about your build you said people love them elaborate more , i am excited to build a pair do i missed somebody that actually built them on this thread ? chime in if i did |
#70 |
hi maxo
i have not bild this one,so can't help you there. al the numbers are right,and its an easy bild. i'd say go for it. see post 24 to 26 and post 36
| simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak? | mige0 | Software Tools | 19 | 29th December 2010 04:00 AM |
| FS: BG Neo3 PDR - Special OEM "Deep-Back" Version | mac | Swap Meet | 1 | 19th November 2010 04:11 AM |
| 3015lf? | mike james 533 | Subwoofers | 29 | 18th April 2010 01:00 AM |
| Driver in deep baffle"tunnel" | marcus1 | Multi-Way | 4 | 6th December 2009 07:18 PM |
