#51 |
first dril a hole,then cut it out with a jigsaw.
its not nessesery to cut them out,it just saves some weight.
one good thing about music ,when it hit you feel no pain. so hit me with music.
#52 |
Drill a hole to start (big enough to insert the blade through) then use a jig saw / air saw.
Or a router if you don't have a jigsaw (but they're cheap Go pick one up) |
#53 |
Whoops didn't see your reply lol
#54 |
Ic,
hey any recommended or minimum list of tolls for a newbie woodbutcher just the basics to build this box plus choice of hurricane nuts, and gasket and backplate people like duratex, but i read somebody used truck bed liner also do you need to stuff the inside with damping material or no Last edited by maxo; 7th January 2013 at 06:14 PM. |
#55 |
first of all ,get help from a more experiance dude.
its not rocket sience,but a little help is always welcome . you need polyuteran glue,and gun. 4x40mm screws,screwmachine. screw every 3"starting 2"from the ends. woodclamps are usefull . i'd use t-nuts connection plates,any wil do. on this side ,of the pond whe use warnex with a roller like this i would round the edges ,so it won't dammage so easy. no damping is neede in this type of box
#56 |
Epa
who you will be a good candidate to ask for advice on the cut list there is only 2 braces, looks like they are the ones attached to the baffle what about the top one also, what about if i add some ribs like i sketched on post #43 instead of making a "to fit" brace from front to baffle and baffle to back panel ( you need to cut to spec ) ribs are easier to glue on
#57 |
why not get your wood cut where you buy it.
if you show the plan's it should be easy to cut on a saw table or a vertical plane saw.
#58 |
oh and the top brace is made of left over scrap,
is there no one in the neigberhood of texas here on the diy sub forum?
#59 |
I dont know... looks like i am alone
![]() LOL !! hey can anybody post a high res cut list like on post 23 i tryed to make it bigger but i get a lot of pixelation
#60 |
this you can give to the carpenter/someone with a sawtable.
i numbered the cuts ,so every thing becomes the right width.
| simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak? | mige0 | Software Tools | 19 | 29th December 2010 04:00 AM |
| FS: BG Neo3 PDR - Special OEM "Deep-Back" Version | mac | Swap Meet | 1 | 19th November 2010 04:11 AM |
| 3015lf? | mike james 533 | Subwoofers | 29 | 18th April 2010 01:00 AM |
| Driver in deep baffle"tunnel" | marcus1 | Multi-Way | 4 | 6th December 2009 07:18 PM |
